My saga with front wheel splash guard continues
Old Jun 2, 2009 | 03:49 PM
hmr1979's Avatar
I replaced my other on the driver side not too long ago because the bottom was starting to wear out with a 4 inch hole..
Well this time, the other side..... just came off, right when I on the hwy!!! not goood.
I felt this huge rush of air coming inside the AC vents and I just thought the AC unit was going crazy so I pulled over. I figured it had to do with with air/or intake or some sort. So I went outside and looked under the car, and sure enough.
Normally it wouldn't bother me that much, but the bad news is that the thing came off and was stuck towards the wheel. So without knowing , I was grinding it with my bran new GY tires,......really really put a damper on my mood today. I noticed plastic black stuff all over my tire, is this going to be ok? I figure this might just rub off as I drive off, but I dunno. Any thoughts?
Luckily it's just one tire.
There goes 63 dollars down the drain. Which could have gone to the rear spoiler I have been wanting...grrrrr
oh ya the title was suppose to say "saga" i dunno how to edit the title.
Old Jun 2, 2009 | 07:15 PM
Lovemycar's Avatar
Never seen that one
Old Jun 2, 2009 | 07:38 PM
ILL-Maxima's Avatar
dam that sux man... the tire doesn't look that badly damaged to me. just some surface scrape. did you notice any cuts in the thread? i doubt the plastic was that strong enough to cause that though.
Old Jun 2, 2009 | 08:39 PM
chernmax's Avatar
Nations 1st 6th Gen Turbo
Are you still on the side of the Hwy waiting for an answer???
Anyway if you do not see any nicks or chucks taken out of the tire, you should be OK...
Old Jun 2, 2009 | 10:07 PM
hmr1979's Avatar
LOL Actually a cop was right in front of me when I pulled over and that B--stard neva even came to see what was up if I needed help
I put ina new liner and just got done a couple of hours ago, this time I went to Lowes and bought bolts and nuts and big washers for all the holes that I had access on both sides.
The plastic residue came off pretty easy, I just did a couple of hard starts from a couple of stop signs and that seemed to do the trick, she looks clean.
Taking off the tires and seeing my rotors really really really makes me want to put new rotors on this puppy already.
Old Jun 2, 2009 | 10:09 PM
hmr1979's Avatar
Ya youre right, it wasn't strong enough to do anything to the tires. I was really worried that it was going to damage the Boot. Cause I just replaced that thing, and I was praying when I took the wheels off that the boot was going to be unharmed...but she is good, just a lil tiny scratch but it didn't cut it.
Old Jun 2, 2009 | 10:16 PM
J. Cook's Avatar
Bro I feel yeah mine came loose as well and I burned a hole right through it just like you did. I couldnt tell from the pics but are you lowered? And I didnt know that the inside plastics were only 63 dollars I may just have to try and get me another one, after I figure out why in the hell it wont start!!!!!!
Old Jun 3, 2009 | 08:04 AM
hmr1979's Avatar
Nope, not lowered. And actually there is a non-genuine nissan one that is identical in fitment but it only cost 30 bucks. A local shop out here could have ordered it, but someone on this forum told me the material on that one is not as sturdy? I Just wanted to replace it asap so thats why i went to stealership
some other ones quoted me 90 to 100.
I am still missing the splash guard underneath the engine
Old Jun 3, 2009 | 11:39 AM
Lovemycar's Avatar
wow never seen that one happen really
Old Jun 3, 2009 | 02:29 PM
hmr1979's Avatar
lol you must be really surprise cause you said this yesterday.
She is back to pretty now. Bolted them at the bottom so hopefully it should withstand some ....relatively high speeds
Can someone tell me if the splash guard is suppose to go inside the bottom bumper or over like i have it there? Now I am thinking it's suppose to go under...I did the other side a few months ago and i did it this way so Ijust thought it would be this way...but maybe I have it on wrong.
Old Jun 3, 2009 | 03:35 PM
J. Cook's Avatar
I believe it goes inside
Old Jun 3, 2009 | 04:33 PM
thealliance43's Avatar
im just about to replace mine too... i have a hole in my passanger side... i ordered mine through everythingnissan.com and it got somewhat bent from shipping i'm hoping when i install it i wont run into the problem where im drivin and it falls off... i hear you though hopfully this will hold
Old Jun 3, 2009 | 06:27 PM
J. Cook's Avatar
Thanks for the link thealliance43 one question though were you able to view any of the parts? Cause I tried and their were no pics. you ordered ours without looking at them?
Old Jun 4, 2009 | 07:51 AM
hmr1979's Avatar
What part is bent? Since it's a liner, I doubt a bend would really matter.
Old Jun 4, 2009 | 08:06 AM
hmr1979's Avatar
$hit lol
i guess i'll have to redo it when I change my rotors and headlight bulbs.
doctorpullit
Apr 5, 2017 12:59 PM
homeyclaus
Sep 3, 2015 06:15 PM
seesole
Aug 26, 2015 11:22 AM
twotonezed
Aug 16, 2015 11:41 AM
BassAddictJ
Aug 4, 2015 11:38 AM
