Light squealing under the hood when cool
Old Jun 4, 2009 | 07:11 PM
A5703's Avatar
I have an 05 max SE with 31k miles on it. After I cut the car on and accelerate off for the 1st couple blocks, I hear a faint squealing under the hood. This lasts for just a second or two at a time, for the first couple starts, then it goes away. Maybe it's the belts, but it does not sound like the traditional belt chirping I have heard in cars past. Any ideas?
Old Jun 4, 2009 | 07:21 PM
04LowLife's Avatar
My 04 is doing the same sorta thing but I think mine is the alternator
Old Jun 5, 2009 | 08:07 AM
frankp's Avatar
Our 05 Maxima with 3.5 started making a "squealing" noise a few weeks ago. It would get higher and lower based on the rpm of the engine. I did some research and found the the timing belt tensionos is some Nissans were failing prematurly and needed to be replaced. Went to the dealer and sure enough that was the problem. Luckily with only 28k miles it was covered under warrenty otherwise may have been as high as $1500.00.
Frank
Old Jun 5, 2009 | 08:20 AM
The Presence's Avatar
Double check the belts as well as your Idler Pulley
for your Ac & Alt. The bearing inside could be bad.
Old Jun 28, 2009 | 06:20 PM
Maxy04SE's Avatar
mine has a little belt-like sound that happens during idling after not starting the car for at least 2 days... but that goes away by warmup and it hasn't been a concern yet.
trasmadean
Jan 20, 2018 05:05 AM
02PearlSE
Oct 7, 2015 02:12 AM
Viralkill
Aug 17, 2015 10:54 AM
Viralkill
Aug 16, 2015 05:09 PM
doobadoo
Aug 15, 2015 06:43 PM
