Oil Pan gasket replacement?
Old Jul 2, 2009 | 05:56 AM
BlackSpeed's Avatar
Has anyone attempted to replace the oil pan gasket in the 6th gen? I read the service manual and it recommended the O-ring change also. Could someone chime in?
Old Jul 2, 2009 | 05:51 PM
mynameispee's Avatar
don't think there is a gasket replacement, just reseal it with some rtv and you should be good.
Old Jul 2, 2009 | 08:33 PM
str8max's Avatar
There is a gasket made by felpro.... Autozone has it!
I am getting ready to do this on my 5th Gen. same gasket
Old Jul 2, 2009 | 09:37 PM
i guess i stand corrected. i usually just reseal it with some rtv.
Old Jul 2, 2009 | 09:47 PM
str8max's Avatar
I do have a question though.... If you use the gasket is there a reason to also use RTV?
One guy in the 5th gen forum said it would make a better seal!
Old Jul 3, 2009 | 09:41 AM
BlackSpeed's Avatar
There are actually two gaskets. Once called the lower oil pan gasket which is the traditional shaped gasket. You then have to remove the upper oil pan which has two half moon shaped gaskets. The RTV is required when bolting the upper pan back to the block..
Old Jul 3, 2009 | 10:20 AM
pmohr's Avatar
No more Maximas...
I wouldn't even bother with using an actual gasket for the lower pan, I've never had an issue sealing them up with RTV (the same way they come from the factory).
But it really depends on which oil pan you're talking about.
Old Jul 3, 2009 | 10:29 AM
str8max's Avatar
ok I should have been more clear..... I need to replace the lower.
Old Jul 3, 2009 | 10:48 AM
str8max's Avatar
I was just wondering if the gasket would make as good of a seal?
PH98I30
Jan 9, 2025 08:08 AM
Matt93SE
Apr 8, 2018 09:23 AM
iflexsteel
Sep 15, 2015 03:37 AM
MAXSE5SPD
Aug 23, 2015 12:06 PM
maxima297
Aug 3, 2015 12:50 PM
