engine rattle? and squeaky belts? fun fun fun :(
Old Jul 23, 2009 | 01:52 PM
lighty0770's Avatar
i have a rattle around 3k rpm when its shifting to the next gear. it rattles constantly and doesn't go away until i either surpass 2500-3500 rpm. i have been told it might be my heat shield and i should get them removed? any suggestions or comments?
also... i have had my car for a while and sometimes the belts squeak a little bit and i don't think anything of it because its just the belts squeaking. Then yesterday i started my car up twice and both times it squealed profusely and didn't go away for a solid ten seconds. immediately following the squealing i smelled burnt rubber. is it possible that the belt is slipping and if so which belt is it?
Old Jul 23, 2009 | 07:04 PM
chris350's Avatar
i would just replace all the belts once you head squeeling from the belts..belts are worn..just do all and save yourself the hassle.
as for the rattleing...your gonna have to get a flash light and narrow it down or let your mechanic check it out. could just be the tensioner for the belts or any number of things.
Old Jul 24, 2009 | 01:21 PM
VigilanteMax's Avatar
heat shield or exhaust bracket...remove either or both. Change belts or tighten.
Old Jul 24, 2009 | 01:25 PM
DeusExMaxima's Avatar
I have a UDP and my AC belt squealed from day one until car is warmed p.
markevans999
Oct 25, 2015 08:27 AM
DarjeelingRose
Sep 15, 2015 01:20 AM
Krazzespiinz
Sep 13, 2015 07:10 AM
thenewguyy
Sep 12, 2015 11:12 AM
NissanNismoZ
Sep 12, 2015 07:30 AM
