maxima blowing cold air while idling
Old Sep 21, 2009 | 06:31 AM
burtinos's Avatar
hello everyone, i have a 2004 nissan maxima sl. when the car is warmed up and the car is idling the heater will blow cool air, but when i am driving the car blows hot air like it supposed to. any input as to the problem is apreciated
Old Sep 21, 2009 | 06:59 PM
1hawaii50's Avatar
My first guess would be a clogged heater core. I would do a really good flush on the cooling system using one of the chemical treatments from NAPA. I had this problem on my Taurus, and ended up replacing the heater core. Not sure whats involved in a heater core for the Max, but I had to pull the complete dash for the Taurus...lots of fun when you're working by yourself.
Old Sep 21, 2009 | 07:52 PM
fflint_18's Avatar
Or a soon to be bad water pump. At idle it's not moving enough water through the core to give you heat.
Give it a flush and pray.
Never did a 6th gen core, but my guess is it's a pain. I think I'd rather do the pump.
Good luck.
Old Sep 22, 2009 | 06:06 PM
DAlastDON's Avatar
Make sure you coolant level is full.
You could have an air bubble and need to "burp" the cooling system.
A coolant flush never hurts. I Flush my vehicles every 2 years. It helps in preventing clogged heater cores and failing water pumps. Preventive maintenance goes a long way.
Dude, i feel your pain on the Taurus. This past weekend i changed the heater core in my brothers 1997 Taurus. I had no idea what i had gotten myself into until after i got started. Complete disassembly of the lower and middle dash including dropping the steering column to the floor. I have never taken a dash apart that much. It took me 9 hours to do the job by myself. He has had the car since 1998 and has almost 300k miles on it without a coolant flush. He is the worst when it comes to taking care of his car.
Old Sep 22, 2009 | 06:20 PM
fflint_18's Avatar
Every Taurus of that generation has has a heater core issue no matter the miles.
And because of the multiple thousands people want to chargee for what you did allot either sell the car or go without heat.
Old Sep 23, 2009 | 03:12 AM
po8pimp's Avatar
had same problem, it is air in you coolant lines. easy to fix. i will find instructions from an earlier thread
Old Oct 7, 2009 | 11:11 AM
cheeo's Avatar
hey i have the same problem, could someone post how to fix the air in the coolant lines please
Old Oct 8, 2009 | 05:40 PM
hey11101's Avatar
Same problem here also, if anyone knows how to fix this easily that would be a great help.
Old Oct 8, 2009 | 09:53 PM
DAlastDON's Avatar
http://forums.maxima.org/6th-generat...air-lines.html
Old Oct 12, 2009 | 06:37 AM
ubersl's Avatar
Twice I did coolant flush at the dealer and both times I got this problem. Had to go back so they could get rid of air in the system. There is a factory procedure (TSB) on doing it yourself. It takes about 1 hour.
Old Oct 21, 2009 | 11:06 PM
cheeo's Avatar
just an update with mine. i tried to get the air out myself, but that didnt work so i brought it to the dealership and they said i had a bad rad cap that was letting air seep in.. they charged me something like $26 for the cap and bled the line and its working fine now.
Old Jan 7, 2010 | 07:20 AM
Anglea's Avatar
HEATER BLOWING COLD WHEN IDLING
Hello, I am new to the forum but got some great help yesterday so I wanted to respond. Had the issue of heater blowing cold in my 07 Maxima when idling but otherwise it worked fine. I parked on an uphill slope in the driveway and as advised removed the radiator cap and bled some air bubbles out of the radiator and filled the overflow bottle to the upper limit. I then drove the car and repeated the bleeding process and my heater now works perfectly! Thanks for the advise!
maxinout93
Oct 27, 2015 01:29 PM
cheftoo
Aug 20, 2015 05:17 AM
acw
Aug 13, 2015 12:50 AM
Balkins
Aug 12, 2015 06:39 AM
kirkhilles
Aug 8, 2015 10:53 AM
