Resetting Airbag Control Module on 2006 Maxima
Old Oct 4, 2009 | 04:45 PM
x2dus's Avatar
Just finished installing the curtain airbag on my o6 max, from what I was told now I need to reset the airbag control module to turn off the airbag light but I can't find any info on where it's located. I rather do it myself then taking it to the dealer if it's not that difficult to do.
Old Oct 4, 2009 | 09:47 PM
oldngivout's Avatar
Willing to learn
This is what you need:
http://cgi.ebay.com/ebaymotors/altim...=p4506.c0.m245
I have used this service and it works fine. The dealer cannot reset the module; they can only sell you a new one. Yours is located under the center console.
Old Oct 5, 2009 | 03:07 PM
x2dus's Avatar
thanks for the info..lots of screws but I finally got to it, now I'm sending it out and hopefully when it gets back and I put it in that airbag light will be gone
Old Oct 9, 2009 | 11:30 AM
x2dus's Avatar
ok, I received the control module and after I installed it the light didn't turn off even with all the reset tricks I've read on here so I took the car to the stealership and they found code B1129. They told me that I need a front R/H Seat Back assembly and side airbag module, also Airbag Diagnosis sensor unit and harness. I can't find none of these on ebay and they want more than $2700 to fix this. Does anyone know where I can find these parts cheap because this flashing airbag light has got me ready to sell this car already.
Old Oct 9, 2009 | 11:32 AM
Stormzusmc's Avatar
look for a parts car youll find it eventually, may take some time
Old Dec 19, 2009 | 02:36 AM
x2dus's Avatar
ok the FRONT R/H SEAT BACK ASSEMBLY AND SIDE AIR BAG MODULE AND the AIR BAG DIAGNOSIS SENSOR UNIT AND HARNESS AND HARNESS which the nissan dealer stated I needed at a whopping $2,435.21 plus tax and $250 in labor turned out to be the little airbag on the inside of the seat with the wire and connector which I purchased for no lie a measly $31 thanks to ebay. Installed it in 15 min and the annoying airbag light has been gone since.
SmokinMax02
18
Sep 11, 2015 12:25 AM
Flores94
Aug 13, 2015 01:17 PM
cmpowell86
Aug 10, 2015 12:35 AM
kirkhilles
Aug 8, 2015 10:53 AM
Tanvirkamal
Aug 5, 2015 01:32 AM
