cloggged catalytic converter!!!!
#41
http://forums.maxima.org/7419255-post46.html
Cattman says "Remove or replace that front precat soon. Many of the Maxima pre-cat substrates (the active core) start disintegrating into fine sand sometime after the CEL goes off, and small amounts get sucked into those 3 cylinders, which destroys the motor pretty quickly. Like I tell my customers, if you've recently noticed increased oil consumption (following a failed front precat), its already too late." [/URL]
#42
Thank goodness I don't have that.
I feel comfortable doing brake pads, bleeding brakes, oil, rotating tires, etc, I just wish I felt comfortable doing exhaust or I would've looked into adding the Cattman system to this car. Can't wait to see how much this is going to cost.
#43
dave, headers are not a bad install at all. Me and a friend did it on a garage floor with jack stands in a day. We had air tools, but they didn't necessarily make the job any easier, just less strenuous. grab a friend and go for it
#44
hey Jay I PMed you might be able to help you out.
#45
I have jack stands and a floor jack, just afraid getting under the car because I'm basically a hack who googles stuff and then goes in full force. Knowing my luck the car would fall on me because I had the jack stands in the wrong place.
If I think about it, I'll post my receipt so others can see it for future issues.
While the car is there, I'm having him replace the plugs too. That's another $350. Not sure I trust any of the local guys w/ this.
After this repair, I think this is going to be my last Max. I might have to go with the grocery-getter car next time like a Camry.
BTW, I think a lot of my Max issues have to do w/ living in Cleveland and the tough winters. Seems like the Maximas like warmer weather and no corrosive salt.
#46
What year is your car? Cats are covered for 8 years/80,000 miles...
If you're out of warranty... get some Cattman headers!
P.S. I wouldn't drive the car until you get the parts to get this fixed. The catalytic honeycomb material will get sucked into your engine and... kablooey.
#48
#49
well guys my ses light came on today so i went to get it read expecting to get a p0430 for my hollowed out cat, which i did but i also got a pending p0420. What i am wondering is if it is pending does that mean it is on the way out or should i keep driving it?
#50
Nations 1st 6th Gen Turbo
Just in case anyone was curious. Attached is my final bill.
$1,686 for 3-way cat, gaskets, and labor
$377 for install of 6 new Nissan spark plugs
CLICK ME
CLICK ME
#52
When is it coming? anytime before the end of the year?
Ah this is what I overlooked and saw last time. I believe this is what I am really looking for given the winter and the weather more central Canada. In Vancouver you guys never see -30c to -40c weather along with a windchill factor that freezes your ears in 1 minute.
Which is one of the main reasons I did not see the headers as a viable solution given the climate I drive my car in. You got a breakdown of how much these replacement HAF cats will cost, along with install time, and build material? (hopefully rust proof).
#55
#56
weather
The big kicker here is our weather, i'm not talking just severe cold, literally more the elements. Running wiring for an o2 sensor knowingly exposed to salt, snow, slush, and just plain bad weather in general during the winter season.
Even though I use heat shrink tubing and put like 2-4 layers of it on my soldered joints for the o2 sensor the condensation will eventually get to it. would not be able to make it near as good as how block heater cords are made to stand our winter weather.
My vehicle unfortunately is to be used all year round, at many times I thought of trying the possibility of just making it a summer car... The wife disapproved...
#60
I thought I would give everyone an update with my failed cats. I did not want to pay for headers install and racingline cats were not available. What I did is hollow out both precats and add a ypipe and I noticed some pretty nice power gains. As far as the check engine light all you need is o2 sensor spacers. They do work. I have driven the car for 3500 miles with only a cel coming up once for a p0507 (idle intake air control) which has nothing to do with the emissions. I just thought I would share my method of dealing with the dreaded P0420 precat code.
#62
Hollowing out the cats was one option I thought about, my tech recommended against it, only because you really have to make sure you get all of that material out of there. You do not want it going back into the engine, it can scratch the cylinders or something in there and ruin your engine. I do think it is a viable option though, just be careful to due a thorough job.
Tell me:
1. How did you (or someone else) do it?
2. List all your CEL codes. When was the last time you checked because more could be piling up under your initial code.
Tell me:
#63
Tell me:
Tell me:
The front cat bank 2 is easy to access so they took that one off and hollowed it out the back one was much more labor intensive so I told him to cut it and then ream the housing. I had this done with a racingline ypipe and all crimps removed and magnaflow 14805's and it sounds amazing. Before I had the cats remove there was a p0420 code. Now with 3500 miles I've only had a p0507 whice may have something to do with the jet maf. Im not too sure. Also I went and had the code read right when it turned on. Tightened everything down on the intake and maf and the code hasnt returned since so I know for a fact that there are none piling up. The only downside so far to all this is that the exhaust has a very unusual odor and ive noticed that if I downshift to let the motor slow the car when the rpms hit 1100 they surge 1 time to 1600 then back down to where they should be...... Sounds weird I know.
#65
Thanks, Jay
#66
What trouble are you referring to?
We have basically the same mods except you are almost stock for your intake. I have Fujita CAI soon to be on RC2. I guess that's why you aren't getting any lean codes.
I'm running SAFCII, I didn't go Technosquare only because I was afraid to start messing with the "brains" of the car that way. I was looking for a spare ECU to use but ran out of $$ and put that project on the back burner. I hope to do that next spring but the 07 bumper conversion mod is calling my name So we shall see what happens.
#67
No emission tests?!? Wow
All that i meant by "trouble" was the extra money to purchase another cat for the ypipe and extend the o2 sensors. After you installed your safc II did you tune it yourself or did you take it to a dyno and let someone else do it? Did youi notice a big difference once it was tuned with the proper air/fuel? Is it mostly cai's that mess up the air/fuel ratio?
#68
Oh yeah, I see. I had my SAFCII tuned at a dyno shop. It really didn't make a huge difference but I think I would be running to lean with out it.
CAI by itself doesn't throw off the a/f ratio too much. But once you add spacers, Y-pipe, catback you open it up enough where you can through a lean code.
No especially since you gutted the cats, I'm suprised you don't have a lean code already.
Tell me about your JET MAF. I bet there are some threads out there.
#69
The only reason that I bought the jef maf is because it was only 60 used from a nycmaximas.org member. Also because chermax said that it is supposed to prevent any low end torque loss due to free flowing exhaust or cai according to a thread that chernmax started a while back. I did not notice much gain though. Did you experience any low end loss with your cai? or only gains? Are they worth the money?
#70
People go back and forth on this but I can tell you with 100% certainty that you will experience some low end loss vs the stock intake. When I first got my Nismo CAI I swapped it back an forth one summer and my conclusion is
CAI = Better highway power, some loss of low end "off the line power"
Stock= Better off the line power but not near as strong from a roll between 55mph -----> or once you hit the 3500rpm mark through redline.
Since I drive about 35miles a day on the highway, it was worth the money to me. My Nismo eventually broke at the bypass filter and I went with a Fujita, which I will be switching out for a RC2 intake soon.
#71
http://forums.maxima.org/6th-generat...ml#post7706395 here they are
#72
I dropped $2300 at dealer last month on my 04 maxima......3 codes were found: p0340 repeated, p1273 and p0420. $1,000 out of that $2,300 was charged for labor. the rest was for a new three way catalytic convertor with new gasket and cam & crank position sensors.
has anyone else on here gone through that or did i just get suckered? well atleast my maxima is running good again!
DayHeyZeus
09-11-2015 03:17 PM
carid
09-09-2015 05:06 AM
