aftermarket HIDs
aftermarket HIDs
my maxima does not come with HIDs so i'm looking to upgrade a kit.
Now my question is I have either the option of D2R(OEM HID) or 9012
Someone told me to get the 9012, because the d2r wouldnt look too good, WOuld i be blinding everything with the D2R?
Yes, you would be blinding everyone on the road, regardless of which bulb you choose. HIDs require HID projectors, which your car does not currently have. D2R (Discharge second generation Reflection) bulbs are designed for reflector-type headlight housings and would not be a good fit for a 6th gen anyway. They would work better for the 5th gen. A better idea would be to just pony up the $600-800 for OEM HID headlight assemblies on Ebay. Plug-n-play!
The d2r bulb is designed for a non-projector style headlamp. The only option without changing your projectors should be a 9006 bulb base. They work just fine for me. Just had to drill a few holes.
HIDs in the 6th gen halogen headlights will not glare, they just don't have as good of an output as HIDs in the 6th gen HID headlights. Some people prefer to do it thoroughly and get all OEM HID components, others are happy just using a HID kit in the halogen projectors. As long as it's an 04+ maxima, a HID kit will not glare.
FYI, though, if you do experience 9012 bulb failure, you can buy brand-new 9012 bulbs here:
http://store.candlepower.com/hirlighting.html
For significantly cheaper than you can at the dealership.
Basically, I just want to know if there is a correct orientation for the bulb, so I know if somethings wrong or the output is just that bad.
