Headlights problems they are haunted.
First off I got an hid kit in my car but thats not the problem. All of a sudden my pass side headlights stopped working so I tried to troubleshoot it today, and swapped the driver stuff to pass and it didn't work still. Like the pass side isn't getting power. So I tore the car apart since I want to put hid projectors in anyways. Ok so I got my hid projectors in and now my Pass side works and driver side is out. I have up last night on that and went to turn them on this morning and again my pass side is out and driver sides works, without even touchging them. Whats up with this i got haunted headlihghts.
All the connections are fine, and i've had headlights on before without starting car and they were fine. I had the one headlight out with car running too. I don't think it's a connection since they are switching what ones off I was thinkin it might be the bcm or that intelligent distribution crap i'm not positive on how all that stuff works. The fuses and relays on the pass side eng comp are all good too.
before anything if you have sounds in your car this might be the problem. i had to this problem before but the cause was my sounds in my car cause my 2 12s were taking to much power so it took power away and messed up my ballast for the light i ended up getting a 2nd battery and a new ballast problem fixed.
i have a relay wiring kit also so thats not the issue. and I had the hid's on the car for awhile and they just started out of nowhere so i'ts not a power issue. With the switching of the headlights like that I think it's somethign else but with the way this car operates them I have no clue, i've read about the bcm or the intelligent power distribution thing but not totally sure how those operate.
AaronL
11-15-2020 11:52 AM
03VQMAX
11-10-2015 03:39 PM
Dennis Twohy
10-01-2015 06:01 PM
