Step on Gas with no RPM Change
Old Aug 31, 2010 | 07:51 PM
StormNYC1's Avatar
Hello,
I just bought an '05 5 speed Auto SE and had some strange issues. Yesterday I was stopped at a light and when it turned green, I stepped on the gas. The car just sat there, continuing to idle, with no increase in RPM. I then shifted into neutral and RPM's behaved normally, increasing as I further pushed the gas pedal. When I shifted back into Drive, the problem continued. The only way I was finally able to get moving was by revving the engine in neutral, then quickly shifting into Drive. This happened a few times that night and I was hoping someone had any suggestions as to what the problem might be. Thanks!
---Paul
Old Aug 31, 2010 | 10:05 PM
NiZMo1o1's Avatar
any SES codes popping up ?
Could be 1 of 2 things,
1 tranny is shot , it finally gave up , how many miles and what year is it ?
2 could be in fail safe mode , check the SES codes and correct them
morteljc's Avatar
do you have a CAI? check your MAF sensor... maybe it is clogged by the oils and dirt of your air intake filter... exact same thing happened to me... and the dealer said that my MAF was clogged by the oils from my CAI filter... worth a try....
Old Aug 31, 2010 | 10:07 PM
chrome91's Avatar
so you revved high in neutral and then went into drive at a high rev? thats basically neutral bombing which will blow your tranny quickly
Old Sep 1, 2010 | 04:18 AM
StormNYC1's Avatar
It is a 2005, with 38k miles. The car worked fine the next day, but it definitely has me worried. I originally thought tranny, but shouldn't the engine revv in drive, even with a blown tranny? It's at the shop now, so I'll see if they pull any codes.
Old Sep 1, 2010 | 04:23 AM
StormNYC1's Avatar
No CAI or aftermarket items. I just bought the car stock from the dealer. The car may have been sitting for a while. I'm not sure if that could influence anything. The car worked fine the next day, so maybe the MAF is having intermittent issues. I'm having the shop check the codes today.
Old Sep 1, 2010 | 04:25 AM
StormNYC1's Avatar
Yeah, it's definitely something I don't want to make a habit of. Next time, I'll just push the car off the road and have the dealer come get it. Thanks for the warning.
Old Sep 1, 2010 | 06:54 AM
21max's Avatar
Sounds like your fly by wire throttle body is going bad or went bad,This is a very common problem with the altimas but ive seen it on a few maximas.......
Old Sep 5, 2010 | 09:34 AM
StormNYC1's Avatar
Just a quick update:
I brought the car to the dealer and he had it for four days. There were no issues on the way to Nissan (about 10 miles away). Luckily, they were able to reproduce the issue.
The service manager seemed genuinely confused as to the cause, since he wasn't pulling any codes. Eventually, they told me that the tranny fluid was pretty low and they topped it up. In total, they test drove it 3 miles.
It is definitely shifting a bit smoother now, but I'm not convinced that the problem is fixed, since it was intermittent. I also don't know how low tranny fluid could cause those symptoms and why it was low is another concern.
I'll just have to keep driving it and see if anything goes wrong. The warranty is only for two months, so it definitely has me worried.
Old Sep 5, 2010 | 10:00 AM
SmokinMaxSE's Avatar
SmokinMaxSE
Maybe you got a used to be modified car and the owner Sold the parts on here and put the orignal stuff back on.
Old Sep 5, 2010 | 09:54 PM
NIKV69's Avatar
Could be it was in fail safe mode, sometimes it resets itself but the code will pop up soon and car will go back in fail safe mode again
mvm062
Nov 30, 2020 09:00 AM
captchaos
Mar 15, 2016 12:18 PM
slowlifer
Sep 8, 2015 05:53 AM
dcardello
Sep 3, 2015 11:44 PM
sdotcarter
Sep 2, 2015 09:53 PM
