Car is going bonkers! Help!
Old Jan 3, 2011 | 01:48 PM
maxi5's Avatar
Hello everyone I love my 2007 maxima to death and I am having a problem for which it is at the dealer right now and they can't seem to fix. My car will not go above 41 mph and will not shift gears. it will go all the way to 5500 rpm and stay there at 41mph. while accelerating and applying the brake the car has a loud humming noise and very violent clicking sounds that get worse when you brake. As I was driving like this the brake warning light, abs light, traction control light, and slip light all came on and stayed on. When this happened all the noises stopped but the car still wont go out of gear and go above 41. Any advice? Thank you.
Old Jan 3, 2011 | 03:15 PM
SmokinMaxSE's Avatar
SmokinMaxSE
Could be alot of things but I'll say this. When my Alternator went out. I also got the brake/abs/ light only when I hit the brakes but my idle also went very low until it cut off. When my ABS control unit broke, I got the same lights again.
Not being able to go past 41mph, I don't know. I think the 04-06 transmissions has a fail safe mode. Won't shift past a certain gear. But the 07-08 has a different transmission. Check engine light can be alot of things but your lights are related to one thing.
Have you tried disconnecting the battery for one hour? Will reset the ecu. Won't fix anything but just to see what it'll do.
Old Jan 3, 2011 | 05:10 PM
maxi5's Avatar
Turns out it was an abs computer or something and it was sending a signal to shut down the car and the car was fighting it. Needlessw to say the computer or module is broke and they want 1500 to replace it.
Old Jan 3, 2011 | 05:18 PM
SmokinMaxSE
My Max did all of that crap and more before 80,000. My warranty covered all of it $0 deductible. Good luck with that.
Old Jan 3, 2011 | 09:55 PM
po8pimp's Avatar
check the wrecking yards for the part. Make sure you get the right part. Sounds like you are not 100% on what part it is. Find out, post it, and we will even help if we can. Installation might be easier than you think. Find out and let us know so we can help save you some money and down time.
Old Jan 5, 2011 | 06:59 AM
PetitFrereMaxima's Avatar
Man, I love the org! This post cracked me up, lol. But I am soo glad there are always people on here to help each other. I am happy you finally found the problem. I see you have a 07. So, when I find anybody complaining about their 6thgen, espcially the 6.5thgen (07 or 08), I get a little scared for it could happen to me too, lol. Same car and sh*t happens.
Old Jan 5, 2011 | 09:55 AM
Oolatec's Avatar
Sounds like the ABS actuator burned out. Costly! If anything, get the part from them and have a shop do the install. That alone should save you a lot of money.
Old Jan 6, 2011 | 02:35 PM
HMAX08's Avatar
Damn, do you have any warranty? see if that is covered. if not then see if courtesy parts have that part cheaper and have a qualified mechanic fix. will save you lots of money
Old Jul 6, 2020 | 12:15 AM
funnymonroe's Avatar
Not sure if this is the right place to post this but i have a 2004 maxima 6 speed. Ready for this... when I put my car in reverse no lights, but when I go int first or neutral... yep you guessed it... the lights wont go off. Any ideas or suggestions...?
MikesChevelle
Nov 23, 2024 11:17 AM
Lakersallday24
Jun 16, 2019 01:35 AM
kjlouis
Nov 24, 2018 06:09 AM
Balkins
Aug 12, 2015 06:39 AM
altome15
Aug 10, 2015 07:05 PM
