where to get 12 volts from the "ON" signal.
hey, waz up....
I am two toning my headlights, and installing some 3mm super bright led's to accent the headlamps and to also act as DRL.. I am wanting to turn the power on the led's with the "ON" position of the ignition. Any one know of an easy spot and circuit to use to tap into this 12vdc?
I am planning on doing this next weekend, since i have a 4-day vaycay. i will post pics of the mod..
any help would be great, and save some research time...
Well, I did some poking around last night after igot home from work. On 6.5 gen, if you take a look at the fuse block, there is an empty fuse slot on the right column of fuses. I believe it is the fifth from the bottom. This spot is powered by, what else, but the "on" signal. Problem solved.
Pappa Grande
08-15-2001 08:26 AM
