Rear view mirror question...
Old Feb 26, 2012 | 07:14 AM
Raven2490's Avatar
I have a compass and auto dim on rearview mirror and all of the sudden it turned off and won't comeback on. The Garage opener works without a problem. Is there a fuse that fixes the problem or is there a battery I can change?
Thanks in advance
Old Feb 26, 2012 | 03:23 PM
KCMAXX's Avatar
KC's FINEST
You might unplug the mirror for a few. It may reset itself.
Old Feb 26, 2012 | 07:04 PM
Raven2490's Avatar
Tried unplugging, but nothing changed. Still only garage opener works.
Old Feb 26, 2012 | 08:55 PM
T_Behr904's Avatar
The auto dimming feature of the mirror could have just crapped out. I've had that happen to me in the past with previous cars i've owned. After a while of the mirror not working, it will eventually start looking like this...
I'm not sure if auto dimming mirrors can be repaired. I've always replaced mine. The last car I owned with an auto dimming mirror was expensive, so I just replaced it with a standard mirror instead.
Old Feb 26, 2012 | 09:16 PM
DAlastDON's Avatar
In the fuse panel under the dash, check the 10amp fuse, right side, third one up.
Old Feb 27, 2012 | 05:40 PM
Raven2490's Avatar
Checked fuse. 3rd 1 up right side and also the 1 marked mirror on the panel, but all seem to be ok.
Old Feb 27, 2012 | 07:31 PM
DAlastDON's Avatar
Get a new mirror. If the fuse is not blown then the circuit in the mirror is.
Old Feb 27, 2012 | 07:57 PM
Raven2490's Avatar
What about the side view mirrors? those aren't working either. The dimming.
Old Feb 28, 2012 | 10:25 AM
Raven2490's Avatar
Dunno exactly what happened, but the compass came on by itself. everything is back to normal. Nothing I did lol
Old Feb 28, 2012 | 06:39 PM
dee.signs's Avatar
Loose connection?
Old Feb 28, 2012 | 07:24 PM
Raven2490's Avatar
It must be cuz it went out again. I tried messng with connection, but nothing brings it back now. I even tried resetting car by removing battery, but no luck.
Old Feb 28, 2012 | 08:41 PM
DAlastDON's Avatar
The dimming function of the outside mirrors goes through the rear view mirror.
Dunno exactly what happened, but the compass came on by itself. everything is back to normal. Nothing I did lol.
The FSM does not provide any information on the garage door functions but i would assume that the fuse that you checked also supplies power to the garage door opener buttons. Pull that and i bet they quit working. Rules out problems with the wiring before the rear view mirror.
I thinks it is a bad solder joint and i bet if you tap on the mirror it will start functioning intermittently. Get you a soldering iron and open it up and fix it or get a new mirror.
Old Feb 29, 2012 | 11:58 AM
Raven2490's Avatar
I tried tapping, nudging and even punching it LOL no trace of life. Gonna have to try the dealer for estimate to see if it's something that won't cost me $150.
Old Mar 1, 2012 | 08:15 PM
Raven2490's Avatar
While the mirror was alive, I turned car on and off and it kept coming back on. When I started with remote start, it didnt comeback on. Don't know if that rings a bell for anyone? Thanks in advance
matts95max
Apr 23, 2025 10:44 AM
GregL65
Jan 17, 2020 08:01 PM
flu2000
Sep 8, 2015 02:23 PM
