AC cycling issue
Old Jul 18, 2012 | 07:01 PM
scorpion12's Avatar
AC cycling issue
Hey all.
Just two days ago the AC in my 2006 maxima started doing something different. It blew cold air when I first started the car in the afternoon but within a minute or so it began "cycling" or "surging" from cold air to warmer air and back to cold.
I turned the AC off but kept the fan blowing and waited a minute or so. I turned the AC back on and it did the same thing blowing cold then warm then cold.
The AC finally stayed cold after turning the AC off the third time.
It did this two days in a row.
Car has 161,000 plus miles on it. I know the serpentine belt needs to be looked at because it makes a noise.
Could it be the serpentine belt slipping? Or is it more likely the solenoid for the AC compressor clutch?
Old Jul 19, 2012 | 09:48 AM
twentyeggs's Avatar
Originally Posted by scorpion12
Hey all.
you my friend are low on coolant, nothing more nothing less.
Are you hearing the creeping refrigerator sound or ac compressor when you turn the ac on? The reason why it keeps switching from hot to cold is the fluid you do have gets sucked up and goes through the tubing cooling the air, and when it hits the reservoir to be compressed again air fills the tubing and it gets hot. A simple recharge bottle from autozone will fix it. If you have a leak the recharge may not last very long. There is a harmless leak sealant in the refrigerant you buy and if the leak is very small it will fix it, if its big, you will have to bite the bullet and get a new hose. The high pressure hose is usually the one that goes out on our maximas.
Old Jul 19, 2012 | 11:23 AM
Costee's Avatar
Originally Posted by twentyeggs
... The high pressure hose is usually the one that goes out on our maximas.
I thought it was the low pressure/suction hose.
Old Jul 19, 2012 | 03:17 PM
scorpion12's Avatar
How hard is it to use the refill bottle?
Old Jul 19, 2012 | 04:43 PM
oldngivout's Avatar
Willing to learn
You're right, it is.
Old Jul 19, 2012 | 07:36 PM
twentyeggs's Avatar
My mistake, it is the low pressure hose. I replaced both my high and low just a few months ago.
As for the refil bottle, it's as easy as using your eyeballs and pressing a button. If you mess up you are truly unique.
Old Jul 20, 2012 | 04:32 AM
Costee's Avatar
I know our low pressure hose could be cheap material, but a silent culprit of leakage (because it's too tucked away to be seen) is the compressor shaft seal. Following a TSB, I changed the "O" ring of the low pressure hose, but there was no improvement. I then replaced the hose altogether, still no dice until I looked further to discover it was the shaft seal of the compressor that was leaking.
Old Jul 20, 2012 | 11:51 AM
laz000's Avatar
Good info...
Mar 12, 2020 12:06 AM
conansriver
Nov 18, 2015 02:46 PM
wingnut2006
Sep 19, 2015 06:13 AM
BrandonCause
Sep 14, 2015 10:41 PM
Mikes14Max
Advance Paint and Body Work
Sep 14, 2015 05:28 PM
