flex plate?
Old Oct 9, 2012 | 07:20 AM
smokin5s's Avatar
flex plate?
My car at times makes a rattle / chattering noise when the car is under load, if I put it in neutral and rev it, the noise is not there, so it has to be part of the drive train. My transmission shifts rough, but I spoke with the transmission company that did a shift kit and valve body rebuild on the car before I bought it... Could it be a cracked or broken flex plate? How would I check without pulling the transmission out?
Old Oct 11, 2012 | 11:53 AM
po8pimp's Avatar
sounds like the exhaust hairline crack a lot of people had a long time ago. Check under your car towards the engine where the y pipe is and look at the brackets and see if there is a crack. Common issue. I am pretty sure there is a post on here for the fix it.
Old Oct 11, 2012 | 04:44 PM
L36's Avatar
L36
I'm having same issue with my maxima especially when hitting 5K+ RPM while in gear. Guess i have to replace mine, last time i checked it was cracked.
knight_yyz
Nov 1, 2015 01:34 PM
ricky7780
Sep 24, 2015 06:50 PM
