HID Color Change - HELP!
Old Oct 17, 2012 | 09:40 AM
Les7311's Avatar
Passenger side OEM H.I.D. turned a "pinkish" color. Driver side is normal.
What do i fix? New Ballast and / or bulb? Loose connections?
Old Oct 17, 2012 | 09:59 AM
Bassbreaker's Avatar
If it turned pinkish, to me, and i'm not any sort of professional, seems like it is burning at a much higher temp (30,000k vs 5000k) This makes me think that the ballast is letting in more amperage or voltage or something like that. I've never came across a HID that changed colours like that. Only SLIGHTLY or they go out all together
Old Oct 17, 2012 | 10:05 AM
That bulb is going out. Replace both and keep the driverside as a spare.
Old Oct 17, 2012 | 10:28 AM
Prophecy99's Avatar
+1, your bulb is on it's way out.
and searching is your friend.
Old Oct 17, 2012 | 10:30 AM
joecurr's Avatar
+2, on BOTH comments.
Old Oct 17, 2012 | 10:39 AM
VQtHuRtY's Avatar
That's it.
Old Oct 17, 2012 | 04:32 PM
Les7311's Avatar
Bredrins! Nuff Nuff Big Up and Thanks.
Any famous spots to purchase the "bulbs", and is it hard to change? I do change my spark plugs (to grade my technical)....
Old Oct 17, 2012 | 04:43 PM
Les7311's Avatar
wow... found this utube link..... need a seller now... i will buy one bulb if needed.,,,....
Old Oct 17, 2012 | 05:06 PM
AlexxSCM's Avatar
+10 your ballast is bye bye
Old Oct 17, 2012 | 05:21 PM
Les7311's Avatar
Whuutttt ... so i need Balast and Bulb? A.T.A.B.!
Old Oct 17, 2012 | 05:25 PM
AlexxSCM's Avatar
2 of them. They cheap. 35 bucks
Old Oct 17, 2012 | 05:31 PM
Les7311's Avatar
Respeck! Thanks.
Old Oct 17, 2012 | 05:35 PM
AlexxSCM's Avatar
Gl... hey lets see some piccks of your pink eye
Old Oct 17, 2012 | 05:42 PM
Les7311's Avatar
am a site rookie and dont know how to post a pix. but i can text you and you could post ...have 2 pix in my cell i took tonight..
301 379 one 42 four
left side is normal, right side almost looking like a disco light when looking head onn.... gggrrrrrrr
Old Oct 17, 2012 | 06:22 PM
It's not your ballasts and OEM ones are not that cheap.
Old Oct 17, 2012 | 06:55 PM
AlexxSCM's Avatar
I just saw hes a 6th gen. Ddm! If not ballast then what?
Old Oct 17, 2012 | 06:57 PM
AlexxSCM's Avatar
Theres 5 6th gens in my area that have aftermarket hids and they look great and have lasted a long time. Ddm. 35 for both
Old Oct 17, 2012 | 06:59 PM
It's the bulbs. That's what happens when they have a ton of hours on them and they're about to die.
DDM ballasts won't be plug and play for him and aren't as good. He'd also need bulb adapters.
Old Oct 17, 2012 | 09:05 PM
MTR's Avatar
MTR
Agreed I just payed $160 on ebay for a pair with igniter's
Old Oct 18, 2012 | 10:47 AM
Les7311's Avatar
...so does anyone has a spare bulb?
Old Oct 18, 2012 | 11:35 AM
I have a set of D2S bulbs kicking around, never used. What kind do YOU need?
Old Oct 18, 2012 | 11:44 AM
Again, i suggest that you replace BOTH and keep the driverside as a spare.
http://www.theretrofitsource.com/pro...oducts_id=1250
Old Oct 18, 2012 | 12:19 PM
tigersharkdude's Avatar
OP, listen to this man ^^ he's the maxima.org source for all things HID
Old Oct 18, 2012 | 04:39 PM
Les7311's Avatar
Am not a bulb expert here. I would rather the OEM stock for the 05 max HID.... pull that fender off, plug and recover....... this pink-eye hurts!
Is it a D2R or D2S bulb that i need and whats the difference between them, and which one operates the high and low beams in one?
Old Oct 18, 2012 | 08:58 PM
Old Oct 22, 2012 | 01:48 AM
Mr. Blue Sky's Avatar
most reliable source for replacements. theretrofitsource has great customer service, and reasonable pricing for good quality HID parts
The Frye
Sep 2, 2021 11:03 AM
MaxLife17
Jun 27, 2019 01:37 PM
Vistance
Sep 17, 2015 05:17 AM
minsbang
Sep 11, 2015 08:48 PM
MaxLife17
Sep 8, 2015 02:36 PM
