AC/Heat stopped working?
My AC/ Heat recently stopped working as of today. I did notice a little oil or some kind of leak but I dont know what is leaking. I have no idea whats wrong.
First, check your fuses. Then check your physical connections with the equipment and wire integrity, all of them. If all is good, that everything is connected and there is no apparent damage to the wires, then from the battery to the equipment check your voltage numbers, via multimeter, to ensure that there is electricity going to the equipment. Electrical diagnosis...fun times.
![Mad](https://maxima.org/forums/images/smilies/mad.gif)
Thanks for your help!
Well I have power to all fuses, wires are fine as well.
I havent got her off the ground yet but I am thinking the AC/Heat outage is do to a bad blower motor. Now I just have to locate that. Would it be in the dash like behind or under the glove compartment?
Now to where the leak is coming from, I have no idea yet.....lol
Not sure, but you are probably right about the blower motor being behind the dash since there is really no other place for it. Do you know anyone else who has a Maxima? That would be ideal if ya did, for you could just switch em up and you would then know immediately.
As for that leak, ya still got me. That said, I am interested in hearing where it is when you find it!
nice, as for the leaking, I recommend if it is not obvious, to get a puppy pad and lay it under the car and that can help determine what it is leaking. Color and smell are the keys to figuring it out.
jerrod99_se-l
08-27-2015 08:27 PM
kirkhilles
08-08-2015 10:53 AM
