6speed conversion p0335 code
Old Feb 2, 2013 | 07:02 AM
rydewitme's Avatar
I recently did a 5at swap to a 6spd. I used a manual computer and a manual harness. I got the engine to crank and start however, when cranking there is a long delay. I used my diagnostic tool and the code p0335: a crankshaft sensor malfunction code, came up. So I changed the crank sensor and the cam sensor. When I try starting the car up again the problem still persist. For good measures I also checked the wires for the sensor. I am receiving 12v to the power wire. Also my ground wire checked out okay. Does anyone have any suggestions what else I can do ?
Old Feb 6, 2013 | 08:56 PM
MajorReflexes's Avatar
bump i would like to find out what the problem is
Old Oct 17, 2020 | 03:23 PM
Dannick Plourde's Avatar
Nismo
A tu réussie a régler ton problème j'ai le même sauf que le mien étais déjà manuel d'origine, mais j'ai changé pour un moteur qui étais dans un maxima 04 5 vitesse ??Has you succeeded in solving your problem I have the same except that mine was already original manual, but I changed for an engine which was in a maximum 04 5 speed ??
In addition to this, you need to know more about it.
Old Oct 21, 2020 | 10:08 PM
aackshun's Avatar
Check your oil pan to make sure the crank sensor is installed in the correct position (when changing from 5at to manual you will need to change ecus as well as change the upper oil pan)
Old Oct 22, 2020 | 09:38 AM
schmellyfart's Avatar
Also check the post date.
Old Oct 22, 2020 | 03:30 PM
aackshun's Avatar
I saw. Still applies.
ThatGuy2552
Nov 27, 2017 02:32 AM
Patm-a32
Nov 18, 2015 05:23 AM
Daily Interlude
Nov 20, 2004 05:08 AM
cardana24
Apr 22, 2004 04:03 AM
chippychaps
Sep 15, 2003 11:10 AM
