Auto entry/exit - new battery
Old Apr 14, 2013 | 04:23 PM
guywitfreemail's Avatar
I replaced my battery and now the auto entry/exit of the steering wheel and drivers seat do not occur. I checked the settings and they are enabled. Anyone have any clue as to what I can do to regain that function? Thanks
Old Sep 12, 2013 | 03:07 PM
NismoMax80's Avatar
SuPeRmOd
I just experienced the same problem. This did not happen with my 1st battery replacement. Baffled since all fuses are good. Has to be a way to reset it like the sunroof.
Old Sep 14, 2013 | 04:15 AM
NismoMax80's Avatar
SuPeRmOd
Driving enough must have fixed it. Otherwise try:
- Insert key in ignition and turn the key to ON position.
- Open and close the drivers door 2-3 times.
- Close door
- Start engine
- Turn engine OFF
- Remove key
- Open door.
The automatic driver position should work now.
If the above doesn't work, try disconnecting the car battery for about 5-10 minutes and reprogram the system memory again.
Old Nov 6, 2013 | 12:47 PM
Roymg's Avatar
- Close door
- Start engine
- Turn engine OFF
- Remove key
- Open door.
To add a comment to your post:
Is why I let Nissan install my batteries in my 2008 because this problems always shows up and I thought at one time they went into the computer to reset the seats and it may also mess up the sun roof. I'll keep your method in mind, thanks
gigabyte
Jan 6, 2017 06:05 PM
BobTX10
Oct 7, 2015 08:43 AM
bigfrank
Oct 1, 2015 12:51 PM
