08 Steering Wheel Controls not working
Old May 1, 2013 | 10:07 PM
sixpack823's Avatar
I have an 08 Maxima and all of the sudden SOME of the steering wheel buttons have decided to stop working. The volume up button does not work and to change the channel up does not work. (Dont know if it matters, but its a heated steering wheel) This all came about the same time my passenger air bag light started to turn on also and not go off. Any help would be much appreciated. Thanks.
Old May 1, 2013 | 10:09 PM
sixpack823's Avatar
Also my horn
And forgot to mention my horn stopped working also, I will work though if I turn the steering wheel all the way to the right and that is it..
Old May 4, 2013 | 10:17 AM
DAlastDON's Avatar
Bad spiral cable.
Old Aug 25, 2014 | 05:43 PM
lcano's Avatar
spring cable
this spiral cable can stop working from one day to another without being used?
Old Sep 7, 2014 | 04:16 AM
Chris Alexander's Avatar
My Volume does the same thing on my 06 sometimes it work sometimes it doesn't, also the cruise control doesn't work.
Old Sep 8, 2014 | 06:36 AM
james_costanza's Avatar
spiral dable
sounds like it could be the spiral cable (clock spring) located behind the driver side airbag module. I do not know of anyway to check it without replacing it. If you find away let me know. This could cause a B1049 or B1054 code,
Old Oct 17, 2017 | 12:47 PM
agustincorrea's Avatar
Mine only works fine when you turn right the steering wheel.
MikesChevelle
Nov 23, 2024 11:17 AM
trasmadean
Feb 1, 2017 08:20 PM
jhontelj
Aug 17, 2015 04:07 AM
Flores94
Aug 13, 2015 01:17 PM
MikesChevelle
Aug 6, 2015 11:36 AM
