BCM needs to be programmed?
Old May 26, 2013 | 12:17 PM
6thgen's Avatar
Hello,
I am wondering if anyone knows if the 6th gen maxima BCM needs to be programmed? I know the 5th gen an 03 didn't need to be programmed but from what I am reading the 04 may need to be programmed? I do have the chip in the key.
Has anyone had any experience swapping the BCM in a 6th gen car?
Old May 27, 2013 | 07:45 AM
Diablo2424's Avatar
I had my BCM go bad in my Altima SER (06), I also have a chipped key, and granted I had the stealership do the swap, but it did require re-programming of my key... not sure if that helps since I'm an Alti, but it something.
Good luck, it can be an expensive replacement.
Old May 27, 2013 | 03:34 PM
6thgen's Avatar
Thanks for the reply.
Ill try and get the answer from the dealership and see if it does. I tried last time and they really didn't want to answer it. Just the "You need to bring it in to get it diagnosed" answer.
The part new is about $300 at the dealer but on ebay used runs about $60 shipped. Its just the programming part
Old Jun 5, 2013 | 07:31 PM
nsnrider's Avatar
yes, the bcm will need to be reprogrammed with the keys. If you live near western MA I can do it for you. PM me if interested.
Old Jun 6, 2013 | 02:04 PM
6thgen's Avatar
By keys you mean the same method as programming a new fob? I did that before but from what I was told you need the Nissan consult II or something? I did try the bcm and well it didn't start my car lol. Weird all the numbers matched even fcc except for the lot #.
Old Jun 18, 2013 | 05:45 PM
nsnrider's Avatar
no, not like programming a key fob.
Reprogram keys by using consult tool or other suitable tool.
Omar Abdurrahman Siddiqi
Aug 26, 2016 05:18 PM
maxinout93
Oct 16, 2015 02:53 AM
Dasmith
Sep 23, 2015 08:28 PM
QueensMAX
Sep 15, 2015 04:14 AM
flu2000
Sep 14, 2015 12:34 PM
