HELPP!! Heated seat on driver side wobt work!?!????
they are both independent with the exception of the fuse. check the wiring harness for the drivers side under the seat. Other option if that is not working is to take apart the seat and check that you are getting the voltage to the heating coil. If not, it is power related. If you are getting battery voltage readings, then it is the coil. If that is the case, might want to find a junk yard with a used one. You can get aftermarket replacements. Call around and see if there is an upholstry shop near you that can fix it.
shaunkey1
08-18-2015 10:09 PM
KGMtech
08-18-2015 09:21 AM
