P1800 code, need advice
Old Jan 11, 2014 | 04:25 PM
clive's Avatar
100% chingon
Hi guys.
When I bought my car I had a bunch of codes that I am working to fix.
Two that worried me were 1111 (intake valve timing control solenoid bank 1) and 1800 (Vias control solenoid valve)
After reading this up in the FSM I can see how the 1111 code can be caused by the Vias Control valve.
Anyway, I decided to clear the codes and drive it for a bit to see what codes came back. The only code that came back was the P1800. Not the 1111.
I've just been trying to find that valve but I can't see it. Do I need to remove the big black plastic cover first? And, how important is this problem? I'm wondering what it might cost to fix.
Old Jan 11, 2014 | 05:32 PM
SESixSpeed's Avatar
You can easily replace the VIAS sensor yourself in 25 minutes. You will need to remove the black plastic beautification cover (requires allen wrench). Once you do you will see the sensor mounted by just one 10mm bolt. Unplug the electrical circuit, carefully remove the two vacuum hoses that are attached to it and undo the 10mm bolt. Replace and reverse the steps to reinstall.
***Expect to only be able to find the VIAS sensor at the dealership. I exhausted all local auto part stores in my area but was unable to find a replacement part. Nissan Part #14955-8J10A - Valve Asmy06-D4-A (VIAS control solenoid valve) - $198.90***
Link to a picture of the VIAS sensor so you know what you are looking for.
http://www.google.com/imgres?um=1&sa...ed=0CFgQrQMwAg
Old Jan 11, 2014 | 06:04 PM
clive's Avatar
100% chingon
Thanks for the info. I'll do the job myself, I have Allen keys etc.
Good grief - two hundred bucks for that thing? I feel faint. There's my beer money gone.
Old Jan 11, 2014 | 06:06 PM
SESixSpeed's Avatar
I hear ya. It was a christmas present to myself...
Old Jan 12, 2014 | 12:51 AM
Mr. Blue Sky's Avatar
You can also try Rockauto or other sites to see if you can find a replacement. I believe an alternate name for it is "Intake Manifold Runner Control Valve". The picture they have on Rockauto looks the same as the sensor circled in the google images picture given by SESixSpeed.
Found it on Rockauto with that name(in the Engine subsection), as well as O-Reilly auto.
Note: Rockauto has the same Dorman part (#911506 for cheaper than O-Reilly does, $83.00 vs $140)
Old Jan 12, 2014 | 01:10 AM
tosheto's Avatar
Try courtesyparts.com and other web sites that sell Nissan parts. They usually have good prices.
Old Jan 12, 2014 | 10:15 AM
clive's Avatar
100% chingon
Great help, thanks guys. I'm going to take it off the car today and examine the thing. No doubt it has been carefully made so as not to be able to take it apart... anyway, it's already broken, it can't get any more broken!
Old Jan 12, 2014 | 11:23 AM
clive's Avatar
100% chingon
Just took off the cover and ... the air hose between the can thing and the solenoid valve is completely broken in half. I guess that might have something to do with it! Off to Autozone to see if I can buy some hose line.
Old Jan 12, 2014 | 01:31 PM
clive's Avatar
100% chingon
Pics of VIAS sensor
The thing is, when I removed the sensor and blow into one of the two tubes, and block the other tube, air comes out of the other side where that rubber sleeve thing is. I discovered that the rubber sleeve just covers a third tube. Surely this rubber part is meant to seal that tube? It doesn't though.
I tried the car after the repair and there wasn't enough suction to move the plunger on the top left of the inlet manifold.
I am guessing that this is due to air leaking past the damn rubber sleeve
Oh well. I tried it with a blocked off rubber tube, no difference, so I replaced that sleeve thing...
Next I got a pair of wires and connected them to the battery. Tried blowing through the sensor tube. It works now! when I have 12V connected to the two sensor terminals it's possible to blow air through, and when the 12V is off, the valve closes. I reinstalled it and tested the engine. Sure enough, just over 1800 rpm the manifold vacuum plunger operated, it's easy to see. Now I need to clear the code and drive for a while to confirm I've fixed it.
Attached Thumbnails P1800 code, need advice-vias-1.jpg   P1800 code, need advice-vias-2.jpg
Old Nov 21, 2014 | 12:05 PM
acw's Avatar
acw
Hey Clive...what happened....did you fix it...did it work out?
LEt us know...thanks!
Mahmuth
Aug 16, 2024 08:23 PM
gigabyte
Jan 6, 2017 06:05 PM
maxinout93
Oct 31, 2015 02:04 AM
dshinn
Sep 26, 2015 08:07 PM
