This Sucks
Old Jan 26, 2014 | 04:54 AM
rbaaron18's Avatar
This Sucks
2008 has no acceleration over 25mph (fail safe) no codes but weird reading from abs (speed is 168mph ) going to meter amp I cleaned corrosion from rear hubs and data from them is normal I have 2 08 max so swapped many parts over including abs module but the problem persists ANY THOUGHTS
Old Jan 26, 2014 | 05:13 AM
D.Stillwell's Avatar
You might have a misfiring coil, often times that will light up the ABS and car will shake. Just an idea...
Old Jan 26, 2014 | 10:29 PM
po8pimp's Avatar
go get it scanned with a consult tool. You should get the live data readout to better diagnose this type of problem.
Old Jan 26, 2014 | 11:21 PM
4th gen maxi's Avatar
Creepin up at night:
Get it scanned and check your freeze frame data, it will tell you exactly what conditions it was in when it set the code
Old Jan 26, 2014 | 11:32 PM
Did you explained you swapped the abs module? ?
There's your problem.!
Ob2 will not recognize that module until you have it sync with the pcm.
On Chrysler products it Will read the different serial code and throw the car into safe mode thinking its being stolen, ALL modules starting with the pcm, bcm, abs got locked and we needed to replace. You can't go swapping parts and drive away. obd2 its easier to diagnose but its not the 90's anymore. Spend the cash to get it scanned, what people do to save a nickel..jeez
Old Jan 27, 2014 | 01:42 AM
tosheto's Avatar
Very descriptive title.
Maxima Pride '07
Sep 12, 2015 07:29 AM
maximusrising
Sep 4, 2015 06:31 PM
paulpearl
Sep 2, 2015 07:50 AM
MikesChevelle
Aug 6, 2015 11:36 AM
