Tranny fluid
Old Feb 15, 2014 | 06:58 PM
jmatusko's Avatar
Tranny fluid
Any recommendations on which ATF to use. I have an 05 and about to service it soon
Old Feb 15, 2014 | 07:42 PM
KevMaster's Avatar
Nissan Matic-K only.
Old Feb 15, 2014 | 11:24 PM
Brian66062's Avatar
Castrol transmax high mileage (green bottle) is rated for matic K. I use it and it seems to work fine. Runs $7/quart at Autozone.
Old Feb 16, 2014 | 10:05 AM
NismoMax80's Avatar
SuPeRmOd
no, use Matic-K ONLY
read the many trans threads/post as to why.
Old Feb 16, 2014 | 04:26 PM
po8pimp's Avatar
Listen to experience in this matter. 6 posts and very good ones I'm sure, however there is a + 1,300 post thread that covers every aspect of the trans and what to not do. You can read it if you'd like, however I can summarize it by telling you to use Matic K only.
Old Feb 16, 2014 | 05:24 PM
mclasser's Avatar
The tranny seems to be the Achilles' heel of this gen so stick with genuine Matic-K.
Old Feb 16, 2014 | 07:57 PM
Kryogen's Avatar
use only the recommended nissan transmission fluid.
It was meant to work with that fluid. Anything else was not meant for this transmission, and might give you issues.
There is no equivalent. Get k matic from nissan.
Since I did a few drains and refill, and now I do it once a year, it solved ALL my transmission issues, and it's super smooth now at 190 000 km, no issues.
(and it was starting to be quite bad 130 000km ago, and it solved all this and never came back). k matic only.
Old Feb 18, 2014 | 02:06 PM
nsnrider's Avatar
i also had a tranny that started having shifting issues, i changed out the fluid right away with nissan matic k fluid (of which was dark and smelled burnt). All shifting issues gone.
change the fluid often, i preffer 25-30 k miles or more often if you beat on it.
Old Feb 18, 2014 | 06:23 PM
po8pimp's Avatar
with this car once a year or 15k is probably a better bet. Of course if you take it easy, just get the fluid sent in to the lab at nissan for analysis.
Old Feb 18, 2014 | 07:02 PM
Samvqftw's Avatar
Nissan Matic K only. You can find it for $8 quart. I got mine from nismoshop.com
HOKUSMAX
Nov 13, 2017 04:34 AM
fx4five
Oct 18, 2015 06:57 PM
Need help
23
Oct 2, 2015 08:56 AM
fx4five
Oct 1, 2015 04:58 AM
