2006 Maxima transmision PROBLEMS
Old Mar 10, 2014 | 07:53 AM
CALYMAN's Avatar
Hey guys I need help, about a month ago I was driving my maxima and I stopped on a red light and when it turned green i tried to move but my car didnt moved. My car didn't shut down but no gear locks in neither the reverse. Last year I rebuild the transmission and it just expired the warranty. Any help will be appreciated PLEASEEEEEEE....
Old Mar 10, 2014 | 09:05 AM
jasoneon's Avatar
I don't have any help to offer, just wanted to say that sucks man.
Old Mar 14, 2014 | 09:06 AM
Quickywd01's Avatar
Replacing an automatic transmission is simple. You can do it in one weekend easily working slow, seriously.
Old Mar 15, 2014 | 06:42 AM
NismoMax80's Avatar
SuPeRmOd
http://forums.maxima.org/6th-generat...ssion-fix.html
Old Mar 16, 2014 | 12:33 PM
po8pimp's Avatar
What type of transmission do you have?
Old Apr 2, 2014 | 01:49 PM
nupe84's Avatar
I am having the exact same issue. My regular mechanic told me the transmission would have to be rebuilt. ($2400.00)
I went to a transmission specialist. They said that it was an electrical issue. He replaced a "relay" but the issue came back. He said it may be an ignition switch or something else but not actually the transmission.
Old Jul 14, 2014 | 08:03 PM
nupe84's Avatar
That all was wrong. Turned out to be my camshaft sensor. I changed the top one today. It took about 30 minutes and I also bought the rear one. Total parts was $140.00. Still better than $2400.00 for a new transmission.
Old Jan 7, 2015 | 06:05 PM
califresh78's Avatar
im having the same issues with my 2006 maxima SE, I was at a red light, it turned green and next thing I knew, my car was not moving in any gear, if my life counted on it. but if my car sat over night, started up cold it would go into gear until vehicle warmed up. im not sure if my issues are camshaft sensors, or valve body/solenoids failures?
I need help really bad. thanks everyone.
Old Jan 8, 2015 | 06:45 AM
nupe84's Avatar
I would go and purchase a cheap OBDII Scanner, even though Nissan uses a CAN I system. You can get one for $50.00. Connect it to your car and see what it finds. You can get them at any auto parts place.
See what codes it finds and then replace those sensors it says are bad.
Old Jan 11, 2015 | 11:25 AM
po8pimp's Avatar
That is your Camshaft Position Sensors. The reason I can tell you that is because of your symptoms. If it works when cold, but not when hot, then that makes the most sense. The Sensors go into the engine and if they are cracked, then the crack will not make them expand/open up until warm or hot. That is what happens to these sensors. Oil/gas mixture gets in them and messes them up.
Lakersallday24
Nov 7, 2024 07:31 PM
Samedi
Aug 13, 2015 04:05 PM
Hawkeye61
Aug 12, 2015 06:45 PM
yat70458
Aug 3, 2015 01:16 PM
