Abs light is still on after i replaced the actuator
hey guys I need help. I recently replaced the abs actuator and a rear left abs sensor and the abs light is still on. When my mechanic used the device to pull codes, its reading rear left abs sensor is bad. I just replaced the rear left abs sensor with a new oem one. What should I do? I spent so much money trying to get the abs system working again.
having the same problem. All the damn lights light up on the dash. I've already changed the two rear speed sensors. Brake light went off, but the rest stayed on. In the process of replacing the actuator now. If this doesn't work, what do I do? What did you do?
MaximaDrvr
08-19-2015 08:20 PM
kirkhilles
08-08-2015 10:53 AM
