Is it my wheel bearings?
Old Apr 7, 2014 | 08:05 AM
mark3857's Avatar
Ovwer the last week or so I have been experiencing a hum/whine in the rear of my car as i drive. As I speed up the pitch is higher as I slow down the pitch is lower. I am assuming it's my rear wheel bearings. I have 90,000 miles on my 07 Maxima. Does this sound like the problem? If so how difficult are theyt o replace? I have the tools and can change brake pads and rotors but thats the extent of my knowledge..... Can you reccomend a place to get install instructions?
Old Apr 7, 2014 | 09:06 AM
NIKV69's Avatar
If it is indeed the rear bearings they are easy. 4 bolts from behind the assembly. Have to whack the rotors a bit to get off but no big deal.
Old Apr 7, 2014 | 10:30 AM
ac max 92's Avatar
Definitely sounds like rear wheel bearings but keep in mind if you've recently changed your tires or if they are worn that can also cause a humming aswell. For myself I have winters and summer tires both on rims and the winters can tend to hum a little where as the summers the noise tends to go away.
Old Apr 7, 2014 | 03:13 PM
myownworld's Avatar
Best way to tell is jack up the back of the car, give the wheel a spin and listen. If there is a whine or grumbling noise, then the wheel bearings are on their way out.
Old Apr 8, 2014 | 09:54 AM
mark3857's Avatar
Thanks for all the good responses!
bbsitum
Sep 6, 2019 07:31 PM
londonflu
40
Sep 25, 2015 09:11 AM
Bonka
Sep 14, 2015 11:18 PM
jfl330
Sep 4, 2015 01:44 PM
boomerbrian
Sep 4, 2015 08:25 AM
