Vias hiss
Old Apr 9, 2014 | 07:17 PM
JBMAX2005's Avatar
Vias hiss
I have a 2005 Maxima SE with 154k miles, and there is a noticeable hiss coming from the cap that covers the vacuum nipple that leads to nowhere on the Vias. When I remove the cap and cover the nipple end with a finger tip, the hiss obviously stops and the idle drops a little. Is this normal? If not, could I just replace the offending plastic cap with a conventional rubber vacuum cap? As an aside, does anyone know why the factory cap is there in the first place? Diagnostic port???
Old Apr 14, 2014 | 09:53 AM
JBMAX2005's Avatar
Anybody???
Old Apr 14, 2014 | 10:18 AM
NmexMAX's Avatar
dot dot dot ...
Shouldn't be a cap, all lines should be functional Do you have any pics of this?
Old Apr 14, 2014 | 11:01 AM
JBMAX2005's Avatar
This is a stock photo I found online. The cap I'm referring to is above and to the right of the harness connection, on the opposite side from where the two vacuum lines attach.
Old Apr 14, 2014 | 11:57 AM
JBMAX2005's Avatar
Here is another pic I found of a Vias with the removal of the plastic cap I was referring to, exposing the vacuum port. Any help would be greatly appreciated.
Old Apr 14, 2014 | 12:06 PM
NmexMAX's Avatar
dot dot dot ...
Pay no attention to what's written, but this is how it should look from the factory.
Old Apr 15, 2014 | 08:47 AM
JBMAX2005's Avatar
I appreciate you taking the time to post those pics, but my problem isn't locating it. My problem is the hissing (leaking?) coming from the vacuum port on the right side that is capped off from the factory. My concern is whether or not it's normal for it to do that. Secondary question is what purpose that capped end serves.
Old Apr 16, 2014 | 03:08 PM
NmexMAX's Avatar
dot dot dot ...
According to the parts explosion diagram, all the ports are functional, that's how mine are, the one in the pic, I've never seen one capped off.
In any case, your cap must be leaking.
Here's mine, little blurry but you can still see it. The picture posted earlier has a BOP, and so therefore no actuator, and the actuator is where the second line should go. Did you buy your car used and if so, does it have a block off plate (BOP)?
Old Apr 16, 2014 | 08:55 PM
JBMAX2005's Avatar
Thanks for sticking with me on this. Yes I just bought the car used. No, there isn't a block off plate. Mine looks just like yours, two vacuum lines attaching to the left side of the vias. But...the part of it that I'm referring to as being "capped off" is as shown in your pic also. It's all the way on the right of the vias, just above the electric harness and closest to the vacuum canister. It's a plastic, oval-ish cap covering a vacuum port. The two pics that I posted earlier in this thread show the vias with and without the suspect cap. I know this is becoming more complicated than it should, but if you look at yours, you will know exactly what I'm talking about. Joe
Old Apr 17, 2014 | 04:10 AM
Kryogen's Avatar
wtf complicated, if you have a leak plug it, I dont know, remove the cap check why its leaking, silicon it and thats it.
if the part is broken get a new one from nissan
trailer54
Nitrous
Nov 18, 2015 07:44 PM
Turbonut
46
Oct 21, 2015 08:28 PM
King_Ten_Ahead
Sep 27, 2015 02:24 PM
Dasmith
Sep 23, 2015 08:28 PM
Kalrakam
Sep 16, 2015 12:30 PM
