car feels like it slows down when I release the gas.....
Old Apr 20, 2014 | 10:36 PM
2DAMAX21's Avatar
When ur driving and your coasting I let go of the gas and it feels as if im lightly touching the brake ...mechanic shop says its rear motor mount coukd this be true? Or is it a transmission problem...PLEASE HELP
Old Apr 20, 2014 | 11:55 PM
Maxima 97 SE's Avatar
Try to see if you have a vdc switch and turn it off because it apples the brakes for better traction when it senses the cars wheel spinning and it also cuts of throttle. Try turning it off and see if that makes a difference. On my 2009 nisssan murano SL I turned it off when I was on the highway and I felt the engine just picked up extra power.
Old Apr 22, 2014 | 04:30 AM
MadMax07SL's Avatar
Could be the mount, but could also be normal. My 07 does the same thing all the time, especially downhill, had it 5 years, had the mounts replaced early on and it still does it. I think it's a Nissan/CVT thing...seen it in the loaner Altima's i've driven too. If you want it to coast but not slow down, you gotta just barely engage the accelerator and it rolls like a GM.
Old Apr 22, 2014 | 06:45 PM
Chris Alexander's Avatar
thats normal the Altima's do it too.
Old Apr 23, 2014 | 01:36 PM
dauntlessmax's Avatar
Your Maxima is designed to do this. It's basically the transmission inducing engine braking. It definitely does feel awkward at times tho...
Old Apr 23, 2014 | 08:09 PM
Kryogen's Avatar
make sure all 4 calipers are sliding properly and no slide pin is sticking.
when is the last time you cleaned and greased your slide pins?
Old Apr 24, 2014 | 12:55 PM
MadMax07SL's Avatar
Outside the "normal behavior" discussion, that suggestion on checking calipers is good info.
As an aside, here's a 7 gen post about this topic...
http://forums.maxima.org/7th-generat...aking-off.html
Lakersallday24
Jun 16, 2019 01:35 AM
Team STILLEN
Aug 10, 2015 04:29 PM
xUNIxPanther
Aug 5, 2015 09:31 AM
yat70458
Aug 3, 2015 01:16 PM
