engine mounts
Old Sep 29, 2015 | 01:44 PM
Pnjboyzz's Avatar
engine mounts
hi guys
i need 4 set of engine mounts for 04 maxima.
dealer is charging almost 1K for these 4 mounts.
can someone please suguest where to get all 4 mounts at cheap price ?
if i go with after market, which band would be good ?
thanks
Old Sep 30, 2015 | 08:47 AM
zillafreak's Avatar
Originally Posted by Pnjboyzz
hi guys
thanks
is that $1000 installed?
Old Sep 30, 2015 | 09:25 AM
NmexMAX's Avatar
dot dot dot ...
eBay usually has good deals on them. How did they determine they were all bad?
Old Sep 30, 2015 | 06:22 PM
Pnjboyzz's Avatar
mechanic showed me the 3 mounts are cracked .
$900 + Tax for 4 mounts and $225 for installed by my mechanic.
Old Sep 30, 2015 | 07:22 PM
wingnut2006's Avatar
Normally only the front, rear and right mounts fail. Rarely do the transmission mount fail. Best to replace with OEM mounts. Yes, they are very expensive. However, others who have replaced with aftermart mounts have complained about vibrations and ended up replacing the aftermart with OEM. Depending on whether you 4 speed or 5 speed auto or 6 speed manual the mounts have minor differences. The front and rear mounts for the 5 speed auto are electronic. oemnissanparts.com and Courtesy Nissan normally have good prices on OEM parts. At one time oemmissanpart offered 35% off list price. Now they offer 27% off. I have purchased from both. They normally ship within a day or two. Both companies are located in the Dallas area so if you live outside the state of Texas the savings on tax will more than pay for the freight. If your mechanic will let you purchase the mounts and install for $225 then jump at the price. Price from Nissan is 2.5 hrs per mount or a total of 7.5 hrs for all three. The front is a real ***** to remove. Good luck
Old Oct 1, 2015 | 05:59 AM
zillafreak's Avatar
I just replaced 2 mounts on my car, the front and the passenger side. Passenger side took like 30 minutes, very simple.
The front was would have been easier but I installed a MMI in it and that made it a little hard to get back in.
Both took me around 2-3hrs with my dad helping. A helping hand with the front out makes it easier. We used a lift and a jack stand to move the mount around to get clearance. At the same time, I did the 3 rear spark plugs and O2 sensor in the back. Not sure if having the intake manifold off helped make the job easier or not.
I only paid $75 shipped for my 2 mounts. $900 for all 4 mounts seems like a huge rip off.
Old Oct 1, 2015 | 07:38 AM
NmexMAX's Avatar
dot dot dot ...
You could always just fill them with the 3M polyurethane stuff.
Old Oct 2, 2015 | 06:11 PM
Pnjboyzz's Avatar
this is the cheapest method i would like to take.
thanks everyone.
Old Oct 7, 2015 | 10:47 PM
maxiiiboy's Avatar
hi guys
thanks
Rockauto.com sells quality parts at very decent price. You should be able to get all four mounts for about $200. Anchor and DEA are good brands.
wyobbagy
Jan 3, 2023 12:03 PM
derekinthez
Nov 13, 2022 04:00 PM
seesole
Sep 14, 2015 12:38 PM
ballerchris510
Sep 11, 2015 05:29 PM
spidgeon
Sep 9, 2015 03:36 PM
