Help
Do you have a check engine light? Normally if the vehicle cranks ok but dies when driving, then starts again after the engine cools down it is the crankshaft sensor not the camshaft sensor. The crankshaft sensor get hot while driving and fails, then cools down and works again until the engine gets hot again. If the sensor is bad be sure and replace with OEM sensor not aftermart. Camshaft sensor normally causes the vehicle to be hard to start and hard/bad automatic transmission shifts but normally will not shut off the engine. Good luck
I took it to a mechanic and it was the cranshaft, thanks for your help!
BrandonCause
09-20-2015 10:20 PM
boomerbrian
09-02-2015 03:46 PM
