Mechanic says I need a new A/C compressor hose and a new condenser hose for my 2008
When I google 2008 Maxima A/c compressor and condenser hoses do come up but they aren't called "compressor hose" or "condenser hose" I know they probably have a different name and I just don't know. The Mechanic said they were leaking and Is what's causing the A/C to blow hot air. Can someone please point me in the direction of the compressor and condenser hose for a 2008 Maxima?
My son has sold his maxima so I do not have the vehicle to look at. The hose that runs from the compressor to dryer is a high pressure hose. Then there is a hose from the dryer to the condenser. That is also a high pressure hose. Then there is another hose that runs from the condenser to the expansion valve/evaporator core. That is also a high pressure hose. That hose from the evaporate core to the compressor is the low pressure hose.
DrewQuinz: Did some additional research and went to Nissan diagram of the AC system. The condenser and dryer are a combined unit so your vehicle only have three lines. The high pressure line from the compressor to the condenser, the line from the condenser to the evaporator core (is steel line and only does not normally fail unless the vehicle has been in an accident and the low pressure hose from the evaporator core to the compressor. Your mechanic is probably referring to the line from the compressor to the condenser.
Yeah i wouldn't replace the compressor unless you know for a fact that it's shot. It's typically the high pressure line which you can replace yourself and get some cheap *** A/C stuff from walmart.. I did and my A/C is blowing colder than a penguins breath.
he said the compressor is fine it was just the hoses that were bad when I googled I saw the high pressure line come up and I assumed that was one of the hoses that needed replacement but I was still confused on the second one.
Jeffery Dee Smith
Jan 30, 2018 04:10 PM
Drewzown
Mar 30, 2016 05:35 PM
evanspears
Mar 25, 2016 03:09 PM
