2004 maxima transmission issues
Old Jan 28, 2017 | 06:06 PM
Donnie1324's Avatar
Bought a 2004 maxima drove great for 30 min. Shut off when I turned on and shift to reverse loud bang and drive same thing. Plus it's stuck in 5th gear and the gears are not showing up on the screen. Should I ditch the car? Everything works awesome beside it seems like abs kicks in at low breaking speeds a bit.
thanks everyone, new to the forum world
Old Jan 28, 2017 | 08:13 PM
SATXBOX's Avatar
Seems like your car is in fail safe mode, alot of issues can cause that car to go in fail safe mode, and make it seem like the transmission is acting up. I would get the car scanned if you don;t have a scanner. In fail safe mode the car makes a loud bang only when you put it in reverse and it drives very slow in other gears.
Old Jan 29, 2017 | 09:06 AM
Donnie1324's Avatar
Transmission range sensor
Thanks for the reply. I scanned it and it comes up with p0705 code transmission range sensor. Any experience with this? Also codes p0455 and p0171
thanks alot
Old Jan 29, 2017 | 09:54 AM
Costee's Avatar
That's (P0705) your park/neutral position switch. Check it out. The part number is 31918-8Y000.
Old Jan 30, 2017 | 06:44 PM
Donnie1324's Avatar
Fixed!
110$ part neutral safety switch and it's as good as new! Thanks for the help! I was ready to ditch the car thoughto the tranny was done
Old Mar 23, 2021 | 08:50 AM
TioFee's Avatar
P0705 still with replacing parts
Hey guys, so I have the same code popping up. I replaced the PNP switch twice, once with aftermarket, other with Nissan part. Code still won't go away and car is stuck in 3rd. Any other ideas as to what could be causing this?
The Nissan part installed was done yesterday. I am extremely confused.
Lauryen828
May 18, 2015 09:14 PM
blackmax6thgen
Nov 13, 2012 10:56 AM
foreeyed
Dec 25, 2010 05:39 AM
Uptown Maxima
May 3, 2009 07:20 PM
