ECU reset
Old Jun 28, 2018 | 07:08 PM
nkf's Avatar
nkf
ECU reset
Hello everyone,
wife's car is driving me nuts. When we purchased the car it had the seal in the timing cover leaking and would set a code. The dealer we picked up the car from offerd to replace the cover. The shop that replaced the cover called and told me the timing chain tensioner as in need of being replaced. And the cams was retarded. So I stopped by the repair shop to see. They replaced it and reset the cam timing.
Now for the fun part. I keep getting codes P0011 and P0021.I clear the codes and a few days later both codes come back. It really shows up when driving the high way. It takes no time for them to come back.
is it the ECU or something else?
Old Jul 2, 2018 | 07:35 AM
freezer's Avatar
It sounds to me like the cams are not set correctly, not an ECU issue. Shop must not have set the timing correctly.
Old Jul 2, 2018 | 02:06 PM
nkf's Avatar
nkf
Is there a way to check cam timing without pulling the front cover off
Old Jul 2, 2018 | 04:23 PM
Costee's Avatar
I think you can read that off the live data of an OBD tool.
Old Jul 2, 2018 | 04:34 PM
nkf's Avatar
nkf
Did not think of that. Time to learn something new today.
Thank you for that!
Old Jul 2, 2018 | 04:50 PM
Costee's Avatar
Specs should be 15 ± 5° BTDC.
Old Jul 2, 2018 | 05:17 PM
nkf's Avatar
nkf
I'll see if mine will ready it. If not I might know of someone that does.
Wonder if I should clear the codes before reading it or leave it.
Old Jul 2, 2018 | 11:44 PM
Costee's Avatar
Error codes do not affect the reading. Read with or without.
metalgod3082
Jan 25, 2013 11:40 AM
incubusjohnny
Apr 4, 2010 09:13 AM
DcMaN
Apr 13, 2005 11:49 AM
maximabebe
Nov 19, 2002 08:22 PM
