Timing problem
Old Nov 18, 2018 | 09:21 AM
Mprice101's Avatar
Timing problem
Hi all, I decided to tackle a water pump replacement, dropped a bolt into the timing cover so the job went from straight forward to Topsy turvy I a millisecond. I have the cover off and have replaced the guides, however, I was mistaken when I thought I had the engine set at TDC, now I can't figure out if my timing is off. When I rotate the crank to light up the notches on the cams and the crank key the right hand bank is pointing to 9 o'clock instead of straight up like the left bank. Can I rotate the right bank to match the left? I'm completely lost, any help would be greatly appreciated.
Phx_Max
Nov 22, 2011 10:01 AM
Firesice18
Jan 18, 2011 05:28 PM
311rulzz
Nov 22, 2010 01:37 PM
densetsu
19
Oct 18, 2009 01:22 PM
Ramius83
Jan 15, 2004 09:39 PM
