2006 maxima shift solenoid
Old Dec 21, 2018 | 04:28 PM
Rudy1's Avatar
so i got a check engine light code p0780 ( shift malfunction) so i took the tranny pan off and took the valve body off and tested the solenoids and all but 1 made a clicking sound. so i replaced that one shift solenoid and reinstalled the valve body and tranny pan anded 5 qts of nissan matic k fluid. started the engine and no check engine light came on but vehicle would not move in drive or reverse. I really need you guys to help me out, Thank you.
Old Dec 22, 2018 | 07:26 AM
Rudy1's Avatar
i dont think i did where would i find information on that i dont have all data or prodemand, plz help
Old Dec 22, 2018 | 10:32 AM
Rudy1's Avatar
would i have to reset the trannsmision??
Old Dec 22, 2018 | 01:26 PM
Costee's Avatar
For that code, your safest bet is a new valve body. Don't need more than 4qrts of Matic K fluid after install.
Old Dec 22, 2018 | 02:33 PM
Rudy1's Avatar
does the shift linkage have anything to do with the valve body??
Old Dec 23, 2018 | 06:48 AM
Costee's Avatar
No. For comprehensive information on what all this is about see
https://maxima.org/forums/6th-genera...ssion-fix.html
Old Dec 24, 2018 | 05:29 PM
Rudy1's Avatar
so it turns out that it was a c shaped thing that goes through the bolt and holds down one of the connector, i was didnt know where to put it at first so i just left it out, turns out its super critical that you install it right because the connector will pop out, also now my vehicle runs but still shifts hard is there a relearn process after the replacement?
Old Dec 24, 2018 | 05:49 PM
Rudy1's Avatar
i added 3.5 qts of matic k fluid and about 2-4 miles, would i need a scan tool to get this done??
MidN1te
55
Aug 7, 2009 05:13 AM
JEXTEL
Jul 28, 2006 11:18 AM
