05 Maxima Steering Wheel Vibration, knocking noise from front end.
Hello all, I have a 2005 Maxima, just had some question, so when i go over 40mph the steering wheel vibrates heavily and gets worse when even faster, as well when the car is slowing down, with out any brakes engaged, i can hear a clunking noise that happens as you slow down, as well when slowing down with brakes the clucking noise is still there and can feel it through the brake pedal. Anyone can help me out i dont know where to start looking, brake and rotors where replace not long ago, Control Arms where replaced at the time of purchase of the vehicle approx 1 1/2 years ago. Can a bad torque converter give be vibration and the knocking sound as its slowing down? any other suggestions of what to look for as well? thank you
just letting you know my maxim is a 04 and I have 0 problems with it cause I take care of my car. if your just gonna be negative and not helpful at all than stay the hell off this forum
good point turbobink. just a suggestion if ya don't have a torque wrench, there 30 at Walmart. set it to 80 ft pounds, remove all the lug nuts than hand tighten them and do not use a impact to install them but instead use the torque wrench in the star pattern to torque them to nissans required 80 pounds of torque. do it to all 4 wheels
Perhaps bad wheel bearing. Easy to check, with the front wheels off the ground, grab top and bottom, try to push and pull, see if there's any play, Also with car in neutral give it a spin, listen and look around. Even with out excessive top to bottom play sometimes it can be a bad bearing, but it would have to hum at speed or diagnose another way.
vqmaxman
04-14-2007 10:40 PM
Dbabo
09-18-2004 12:46 PM
charancon
06-14-2004 08:01 PM
