New Maxima Owner, having issues please help
Old Jun 16, 2019 | 03:02 PM
Travis Boone's Avatar
2 weeks ago, my wife bought her first 2008 Nissan Maxima 3.5 SE. Car ran and drove perfectly fine with 0 issues aside from an o2 sensor, for the first 5-6 days. The other day she was driving to Walmart and the car just lost a majority of the power. It wouldn't get up go and was stuck doing between 10-15 mph. She said tmshe would press the gas pedal and it would go all the way to the floor without increasing rpm or raising the speed.
When I had it scanned for codes it popped these:
C1131 - Engine Signal 2
P1726 - Engine System Error
P2A00 - Oxygen Sensor Bank 1 Sensor 1
P2135 Throttle/pedal Position sensor/switch A/B Voltage Correlation
P3833 - No Definition
P0138 Oxygen Sensor Bank 1 Sensor 2
Now the only code it threw when the vehicle was first purchased was for the o2 sensors. I didnt even get to wait until the weekend to fix those. It threw all the rest of the codes at the same time.
I've tried doing my research and a few things have popped up for me to do, but all result in hundreds a piece per issue. I was hoping someone here may have seen and/or has had experience with this issue before and would be able to help me move forward before I just start blowing tons of money replacing everything.
Thank you for all help and trouble shooting!
Old Jun 16, 2019 | 03:41 PM
bobbyblaze's Avatar
Mine ended up being clogged cats and MAF sensor. My codes did show MAF and CAT banks though.
Old Jun 16, 2019 | 05:35 PM
Originally I was thinking the possibility of a clogged catalytic converter, but started looking at other possibilities because of the lack of a cat code and that I seen it has 2 catalytic converters and wouldn't know which it would have been. But a lot of googling? I only found things bringing up the cat on the radiator side.
Old Jun 17, 2019 | 09:51 AM
Tarzan's Avatar
Start with the throttle pedal position sensor which is on the pedal. I had the same issue, it idled fine but would not rev more than 100 RPM above idle. I re-soldered all the contact points around the white PCB with the resistor tracks inside and had no issues for the next 3 years.
KevMaster
48
Sep 20, 2018 03:16 PM
gworroll
Feb 5, 2017 05:01 PM
villalobos
Jul 5, 2012 11:39 AM
dozu
Jun 1, 2011 07:04 AM
