I think something is missing from my battery cable!
Old Jul 24, 2019 | 05:09 PM
nelgin's Avatar
[Solved] I think something is missing from my battery cable!
Hi all,
2007 Maxima SE. I pulled the battery out because it was dead (It was tested as going bad and wouldn't turn the car over the other day). So I went to put on the new one and saw this. I checked a video or two and this appears to be a 2nd battery cable that should have a loop on the end that fits around the battery terminal. Is this fixable? I don't see the missing part anywhere so it might be down in the engine or something could have been "fixed up" for it to work. I got the car 2nd hand and this is the first time I've had the battery off. Any suggestions on how to fix this?
Last edited by nelgin; Jul 29, 2019 at 12:44 PM. Reason: To let people know the issue is fixed.
Old Jul 24, 2019 | 08:12 PM
RA030726's Avatar
I'm nutty for Nissans
Try to follow it. I'd guess it was for a stereo system.
Old Jul 24, 2019 | 08:34 PM
nelgin's Avatar
No, it's a thick cable that goes into the harness. It's a thick cable.
Old Jul 24, 2019 | 10:05 PM
nelgin's Avatar
Ah, I found another video which seems to show what the problem is. It looks like there's a connector that slots onto the exposed metal piece. It must have got pulled off when I extracted the battery. I don't see it anywhere. I'll have to take a better look when it's light or maybe just have my wife run to the dealer and get one, they can't be expensive.
Old Jul 25, 2019 | 04:48 AM
MadMax07SL's Avatar
Yeah, it corroded off, the top bold is what's holding that sucker on. You need a new cable end...
Old Jul 25, 2019 | 06:48 AM
RA030726's Avatar
Time to get creative. Go to the store and buy a new ring terminal and a tool to crimp it if you don't have anything.
Old Jul 26, 2019 | 02:43 PM
nelgin's Avatar
Ahhh, I see it now. OK. That should be something I can fix easily enough. I'll just have to see if the bolt is still there so I get the right size. Thank you.
Old Jul 28, 2019 | 01:34 AM
nelgin's Avatar
It's incredibly difficult to find the correct connector. I got one from Autozone but it's far too shallow to take a decent grip and it needs to be bent, which is difficult without bending the body of the connector. I think I've just about got it - I was replacing the battery terminal connection too but they gave me the wrong one. I think I'll just clean up the original.
Old Jul 29, 2019 | 12:43 PM
nelgin's Avatar
All fixed and I only have 2 bits left over. One of the 3 screws to hold the bottom of the battery tray in place, not sure if the thread was damaged but decided I can do without it (had to remove it because some pliers fall into the most inaccessible part of the engine!) and the tray the battery fits on - and no way I'm taking that out again, ever. If the battery dies, I'm charging it and selling the car lol.
heem_infinite
Aug 15, 2007 10:02 AM
Nissanx54
Mar 28, 2007 10:34 PM
flyboy216
Dec 5, 2006 06:19 AM
Beerguy
Dec 3, 2004 06:58 AM
blkmaxz95
Oct 27, 2004 09:04 AM
