2007 starts in high gear but shifts manually ok
Old Oct 12, 2019 | 09:02 AM
TheDraft's Avatar
Hello,
Our 2007 just started not to shift? From the start there is no power if you give it gas. If you manually downshift and give it gas it goes like it should.
I'm thinking the CVT is having trouble but after reading on the forum maybe it is something with the speed sensor?
I took out the ABS fuse and the car still did not shift right.
What should I do nest? How do I check the speed sensors or should I change the trans oil?
Thank you.
Old Oct 12, 2019 | 11:51 PM
User1's Avatar
Post your codes.
Old Oct 13, 2019 | 11:51 AM
TheDraft's Avatar
Originally Posted by User1
Post your codes.
No Codes?
I was going to go clean the rear ABS sensors but I feel like i'm wasting my time. When I pulled the fuse the problem was still there?
Old Oct 13, 2019 | 11:56 AM
User1's Avatar
I don't buy it. How did you pull your codes?
And forget about the ABS. Totally unrelated system.
Old Oct 13, 2019 | 12:20 PM
TheDraft's Avatar
The service engine light is not on? So im guessing there are no codes?
Old Oct 13, 2019 | 06:45 PM
User1's Avatar
Don't guess.
Computer controlled cars, folks. Scan tools are a requisite if you want to work on them.
Old Oct 28, 2019 | 03:33 PM
NC00DEK's Avatar
I briefly had a similar problem, it was the brake switch sensor being engaged when my foot wasn't on the brake. It would shift in manual mode but wouldn't downshift in drive. Cruise control also would not engage.
biggz2332
24
Jul 12, 2009 11:24 PM
venturous
25
Jan 30, 2007 05:58 AM
happyricefob
Feb 7, 2003 09:37 PM
Neal728
Jun 18, 2002 11:16 AM
amixam69
Dec 12, 2000 05:50 PM
