Brake lights stay on. Even though I replaced switch
Old Mar 1, 2020 | 09:05 AM
jerroddenny@icloud.com's Avatar
Help me! Brake lamps stay on and cruise control blinks when I try to set speed
replaced the switch. No go,
started pulling fuses and found the fuse was blown. Replaced it and still on.
I was wondering if it could be a bad ground, so then I noticed directly below the brake lights fuse it’s a 10 amp labeled electrical parts. I pulled it out and it’s not blown out but the tail light went off and are acting normal now. So I left it out
This is where im going to confuse you.
Shift lock will not disingage from park and my blinker indicators on the dashboard only work when I put my foot on the brake...
i manually put it in drive and went home .( 60 miles ) drove fine . Still won’t go in park unless I manually depress the button next to the shifter . I need a lil help fellow maxima errrrs
Old Mar 4, 2020 | 11:03 AM
RichardIV's Avatar
Just a shot in the dark, but is your dome light switch broken or doesn't work right? for the 04-06 model years, the dome light switch was garbage and I think it could short the fuse it shares with the brake lights, though I would think that would keep your brake lights off instead of on...
Wouldn't hurt to take a look.
smackdown85
35
Aug 21, 2023 10:05 PM
Tufhchc
Apr 4, 2019 02:59 PM
Tufhchc
Feb 8, 2017 08:51 AM
auveeb
May 18, 2011 06:11 PM
auveeb
May 14, 2011 11:19 PM
