Nwp spacers and throttle body
So that the owners can look cool to pick up chicks. Or dudes.
Unless you are tuning, any performance mod you add is not only useless in terms of performance, but can actually have a negative effect on performance as the stock ECU is now confused from receiving incorrect sensor data throwing all stock programming out the window.
Usually the Big Bore TB shows more responsiveness and more linear throttle inputs...as well as the NMP spacers providing more torque. I noticed the torque factor with the installation of the NWP spacers. Maybe you have a defective VAIS solenoid it usually makes the car feel ball-less if it's not operating. Test your solenoid first they usually fail with an open solenoid using VOM continuity test.
Maxboy23
05-14-2017 10:08 AM
e-subliminal-2
05-11-2010 09:11 AM
