Need help with camshaft wiring
Old Apr 11, 2021 | 04:22 AM
Vellsbells's Avatar
I am changing camshaft bank 1 sensor and my connection is for a crank shaft 3 wire . What do I do
Old Apr 11, 2021 | 05:14 AM
Reality sucks's Avatar
They would also have had to hack the crank sensor to make it work as the Crank sensor has a slightly wider bolt hole center. In your case, You can either buy the Sensor with pig tail. AutoZone and Oreilly's sells the Connector. You could also attempt to shave the upper Tang on the Sensor down until the Connector Fits. Odd's are though the wires on the connector are split as most are. Splice in a New Connector and Be Done.
Old Apr 12, 2021 | 11:46 AM
Vellsbells's Avatar
Hi can I get someone to help I can send money for help online whatever. People are trying to take my car and my ecu is not communicating to obd so I go through bluetooth but then I had 3 different devices on bluetoothe so that was confusing if codes were really true but connection now cannot communicate with ecu but tcu only I think. Regardless I work on cars but I don't have access to schematic
Maxima Fl
Nov 21, 2011 04:50 PM
Mymax97
May 16, 2006 05:24 PM
streetzlegend
Feb 9, 2006 07:36 AM
eturnl
Jan 8, 2005 04:44 PM
