Same 04 max
Old Jul 18, 2021 | 05:31 AM
Jocahox's Avatar
Same 04 max
I changed out both crankshaft sensor cuz the way the car was running and pointed to it so I ordered a cheap set off Amazon and the car ran perfect for a few days than back to not being able to for over 3000 rpm and stuck in 5th s
i scanned it said 1st crankshaft bad so I just bought a much better oem to put in
but took for a drive this morning and acted fine
so not sure what this could be
any ideas ???
Old Jul 18, 2021 | 05:50 AM
I35GEEK's Avatar
Got What You Paid For
any ideas ???
Cheap crankshaft and camshaft sensors from eBay, Amazon or rockauto can be a hit and miss from a longevity perspective. I actually use them myself. I had the same experience as you in that new cheap sensors died within a week or two. However, I also had ones that lasted a good 3 years. So it is unpredictable.
My philosophy about cheap parts: if it is way more less expensive than OEM, if the part is easily replaced and if it is my car, I do go the cheap route. I just keep an extra sensor on hand in my garage in case the part fails prematurely.
However, if it is not my car, the part is difficult to replace and / or price is only slightly cheaper than OEM, I just buy OEM and avoid the headaches. My 2 cents of advice.
Old Jul 18, 2021 | 06:14 AM
Jocahox's Avatar
Thanks I relieved a lil hopefully the new one is good
just a pain in the *** when it goes in limp mode
Old Jul 18, 2021 | 06:17 AM
Jocahox's Avatar
Maybe you can help me with my other questions
as you see in pics I have 2 connectors that have no other connectors around so is it possible that some just don’t get used
Old Jul 18, 2021 | 06:32 AM
I35GEEK's Avatar
Very strange. My car is a 2003 and I do not have unused plugs. I'll let other chime in to see if they have the same issue.
Old Jul 18, 2021 | 07:11 AM
Jocahox's Avatar
Just find it weird I would assume something goes to them but there’s no other ends anywhere
TriggaB21
Sep 25, 2017 09:35 AM
clive
50
May 7, 2006 12:20 AM
Cdriven
18
Nov 26, 2003 12:03 AM
emslave
Oct 23, 2003 08:40 PM
