Help VDC slip light flashing. I give up
Old Dec 23, 2022 | 07:19 AM
Back from the dead's Avatar
Cant seem to solve this one. Slip light flashes, traction control activates at will regardless of conditions. If I stomp the brake pedal it clears up. Also, the brake pedal is very hard to push.
Here's what I've done
Calipers x4
Sensors x4
Rear wheel hubs
Abs rings
Master cylinder
Brake booster
Vacuum lines
Master to abs feed lines
Abs pump and module
Fuses
VDC switch
Clockspring
Gravity sensor
Gravity bled the brakes then
Pressure bled then
Two person manual bleed
I have NOT replaced the Proportioning valve. I don't see how that would make a difference with my issue.
Booster, master, feed lines abs pump and module, sensors all came from an 08 Maxima. They worked in the car. They were tested and confirmed working out of the car.
So yeah whatcha got.
Old Dec 25, 2022 | 02:42 AM
Costee's Avatar
Did you ever run a scan on the ABS?
Old Dec 25, 2022 | 08:55 AM
I did indeed. No codes. Everything functions normal. I had the thought last night to bleed the master itself again. Even though I bench bled it there still might be air
arsonist63086
Oct 13, 2016 12:07 AM
dynamicfigure
22
May 15, 2012 04:27 PM
tsaulz
Nov 17, 2010 09:19 AM
maxatlast
Oct 10, 2005 01:10 PM
ne max
Fluids and Lubricants
May 2, 2005 08:10 AM
