Scraping grinding noise at speeds below 20
Old Feb 11, 2026 | 04:37 PM
Babu Byrapuneni's Avatar
07 maxima sl with 205k. Brake pads and rotors replaced 6 mos ago and used for a month with no problems. Left outside without use for 4 months and took it out yesterday and noticed scraping/grinding noise only at speeds below 20. At speeds above 20, no issue. Need help troubleshooting. Thank you
Old Feb 11, 2026 | 04:42 PM
L36's Avatar
L36
Not an issue. Car sat for 4 months and had surface rust form on rotors. Now as you drive and you brake, the surface rust will be swept away and the rubbing noise will stop. Give it some time, noise will go away.
Old Feb 12, 2026 | 10:08 AM
Just curious. Why would it scrape only at speeds below 20, but not hard braking or high speeds. I can feel the scraping and pulsating in the pedal simultaneously. Anything related to ABS?
the noise is similar to this
https://www.reddit.com/r/MechanicAdvice/s/w83WpwNXuP
https://www.reddit.com/r/MechanicAdvice/s/ykKrc0AMbB
Old Feb 13, 2026 | 06:01 PM
L36's Avatar
L36
At high speeds, you move too fast to hear anything
Old Apr 5, 2026 | 03:15 PM
The problem persists after a month of driving. So, based on some troubleshooting videos, i removed the abs fuse and the sound went away. So it seems abs related. Now how do i figure out if the problem is with abs sensors or abs module. How many abs sensors are even there on this 07 maxima
Old Apr 16, 2026 | 03:27 PM
Figured out the problem. It was the abs sensor. I suspected that. So, got an obd2 scanner and checked the wheel speed sensor readings and found the passenger sensor was erratic. It was rust. Took out the sensor, cleaned the area and now it works and no noise.
latinusmaximus
May 7, 2021 05:00 PM
jrad4real
Feb 10, 2010 05:31 AM
Shogunsc4
Nov 17, 2006 07:05 PM
VIP Maxima
Aug 22, 2004 07:40 AM
GreekMaxima
Dec 19, 2003 09:18 AM
