Seeking help for SUB and AMP if possible
Old Jul 5, 2009 | 01:12 PM
IFuXwiTuZ's Avatar
Unhappy Seeking help for SUB and AMP if possible
hey everyone i have the base model maxima and im trying to get a sub and amp installed in my trunk (yes im doing it myself because i have done it before with no issues but im having SERIOUS issues with this darn car)
im using a hi-low converter to rca cables that go into my amp then from amp into sub (which is pretty much the basic setup)
i cable tested everything and i found the cables to hook up hi-low converter to and it works beautiful but when i turn radio at 18 my amp goes into saftey and i know FOR SURE the sub and amp are fully 100% functional because i had it in my dads mercedes .... i just wanted to pre-wire everything before i go buy my JL setup....
first i tried tapping into the cables from the rear sub speakers under the back window......that didnt work so i was like iight screw that let me tap into the radio deck....so i took off the climate control sectional then removed bottom carbon fiber cover then unscrewed radio deck....did the same wire testing process....NO LUCK!!!! same issue i turn up radio to 18 and amp goes into safety ....does anyone have like pictures or something of there setup so i could look @ and try to fix mine?????
PLEASE im desperatly seeking some help over here... i dont wanna bring it to these radio places because they rush and rip things apart....
Old Jul 5, 2009 | 01:29 PM
tigersharkdude's Avatar
are you running the factory stereo?? If so, that is probably your problem. When I worked at nissan, i put the radios in the new max. They are very complex, as they have so many wires that go from and to the radio
Old Jul 5, 2009 | 02:33 PM
IFuXwiTuZ's Avatar
so your pretty much trying to say im screwed? or its just gonna be a pain in the rear end to hook up?
oh and i am running factory stereo ...thanks for the response
Old Jul 5, 2009 | 03:36 PM
It should be doable, its just gonna be a royal pain in the ****. What radio do you have, pics of the front, rear if possible.
Old Jul 5, 2009 | 06:15 PM
boone's Avatar
You gon' pay what you owe
Based off of what you are describing, it really sounds like your hi-low converter is not functioning properly. Without knowing a great deal about the converter you are using, I cannot say too much but there is typically a gain adjustment that can be lowered. This could very well be the source of your problem if the amp only cuts out at a volume level of 18 or above.
I know I am working with different components in my '05 Max but the principal of what I am doing is the same. I tapped into the speaker level inputs going into my factory subs and connected the speaker level connection to the speaker level inputs on my amp.
Old Jul 7, 2009 | 08:17 AM
IFuXwiTuZ's Avatar
im thinking its the converter also but i already lowered the gains on the converter and the sub...i will post pics of everything i did later on today hopefully you guys could help me out because this is bugging me out and my friend....which is pretty g00d @ doing this stuff....
i dont have the BOSE radio if thats what you guys are asking me but like i said ill post up pics just need to finish work 1st ...
Thanks everyone for there feed back
chisam14
Nov 6, 2018 08:56 PM
sliptap
Sep 30, 2015 05:57 AM
Redfox
Sep 28, 2015 10:41 AM
popdedop
Sep 11, 2015 11:17 AM
