The old hidden key trick
Old Apr 14, 2011 | 08:01 PM
2young2retire's Avatar
I posted this in the wrong forum but it is still good information for Maxima owners. Thing like that happen when you have two forums open at the same time.
Did the hidden key trick today. I had gotten another intelligent key from ebay (matching numbers) and had it programmed at the dealer, $50. I had a plane-jane key cut at Wal-Mart to hide outside to enable me to open the door. The batteryless fob is stashed inside awaiting to be used if necessary. FYI, I did test it to make sure the vehicle would start with it inserted into the recess in the dash. I did the same trick on my Maxima last year. Not too much expense and a whole lot of piece of mind.
Intelligent Key - backup key:
If you want to have a 'emergency key/fob', in case of losing your keys (No, I've never lost my keys, nope, not me...- oh look over there - a LE - let's go hookup our Ipods...)...Anyway...to do this:
  • Remove the key blade from the fob and hide it on the outside of the MO (ex. using a magnetic key case)
  • Remove the battery from a working fob so it's not 'active' - i.e. receiving radio waves from MO - and can be locked inside MO and the battery is not necessary (see above tip)
  • Hide the fob (very very well) inside the MO
Now you have a backup key/fob for unlocking and starting your MO
Old Apr 14, 2011 | 09:05 PM
eLMo's Avatar
Thanks for the tip, I get it all but what does the abbreviation MO stand for lolol?
Old Apr 14, 2011 | 10:27 PM
Murano. We traded our 2004 LE with a gazillion miles in on a 2011 LE.
We are a two Nissan family. His and Hers, mine is the Max of course.
Old Apr 15, 2011 | 12:21 PM
Ghozt's Avatar
Awesome info, thanks for this! I'm sure there are a bunch of places you can hide a magnetic key on the outside - great idea!
Old Apr 15, 2011 | 12:40 PM
steevo's Avatar
This is a very interesting idea. Thanks for posting this! I did not know that the fob works with no battery at all, I thought the slot was just for low power.
Fbana41
Aug 29, 2016 12:18 PM
maxinout93
Oct 16, 2015 02:53 AM
jerrod99_se-l
Sep 19, 2015 06:54 AM
conansriver
Sep 11, 2015 10:26 AM
