How to open the dash on 09 Max with Navi
Old May 16, 2011 | 06:58 AM
Ghozt's Avatar
Sorry if this info is somewhere else in the forum, I searched around and wasn't able to find anything.
How do you open up the dash on the 09 Max? I need to get into the dash to the area around the factory stereo and wasn't sure what to start with.
Old May 16, 2011 | 07:03 AM
maxxxxspeed's Avatar
Look here...
http://forums.maxima.org/7th-generat...g-maximas.html
Hope that helps.
Old May 16, 2011 | 08:15 AM
Ghozt's Avatar
This is perfect - thank you. Hell while I'm at it might as well do the DVD bypass as well, that **** is annoying.
What tool did you use to pop the plastic trim? You have a little kit like this gay looking thing or you make something yourself? http://ultimatetoolco.com/panelpopperkit.aspx
Old May 16, 2011 | 08:27 AM
Rking21's Avatar
wait can you watch DVDs in an 09??
tigersharkdude's Avatar
you can use a plastic trim tool or a rather thin flat head with some tape on it, to pop the trim off.
Old May 16, 2011 | 08:35 AM
Ghozt's Avatar
Do you know what area I'm pulling on to pop the trim off? I understand these require some effort so don't want to pull on the wrong thing too hard..
Old May 16, 2011 | 08:59 AM
I started in the top right hand corner on top and pried it there to get it started... and then moved to the top left side and then just popped them the rest of the way out... It take A LOT of effort. More than I thought. I actually used a flat head screw driver with tape and a piece of cardboard because the clips were so tight that it was bending my popping tool. Dont be scared, you will deform the soft dash surrounding the piece you are removing but it will return to its shape in a matter of seconds.
Old May 16, 2011 | 09:00 AM
No I dont think you can... Unless you have the RGB hook ups in the center console, or the NAV in the Dash that plays DVDs.
DO NOT FOLLOW MY DIRECTIONS! That is for NON NAVIGATION.
Old May 16, 2011 | 11:31 AM
Ghozt's Avatar
Is this where you are talking about starting with prying?
And below, are these edges that I marked with red arrows where I'll also have to pry to? Is this whole face piece around the Nav a single unit that comes off with the AC vents attached to it and everything?
Old May 16, 2011 | 11:40 AM
Yes... Once u get the top popped a bit you can just start on one side and pull it out going around that piece... Yes it all comes off as one piece... Then you will undo 2 screws and pop out the bottom "wood piece" the stereo will be behind it. It's held with 4 screws...
Old May 16, 2011 | 11:41 AM
No need to pry where u have in the second pic just do the top to get it started and then pull...the screen is screwed into the frame... Just the surround and vents and buttons come off the screen is not connected
Old May 16, 2011 | 11:42 AM
I jut went out and started pulling and prying and it came off... No need to worry just go do it.
Sorry for multiple posts I am on my phone.
Old May 16, 2011 | 12:10 PM
Ghozt's Avatar
No sweat, thanks for the clarification. As you might imagine I'm a little hesitant to go and start tugging on things on my dash.
HOKUSMAX
Nov 13, 2017 04:34 AM
mikeg75
Nov 30, 2015 05:12 PM
Kingofmaximas24
Nov 12, 2015 04:40 PM
Maxima Pride '07
Sep 12, 2015 07:29 AM
Vequity
Sep 10, 2015 05:26 AM
